Results 1 to 7 of 7
Thread: boring silicone grommets
10-02-2019, 08:00 PM #1
Does anyone have any experience with boring silicone grommets in a lathe?
I think I have the workholding down, but the problem is the tool. I used a 3/8 2 flute endmill oriented like a boring bar to get a high shear angle, but it made a nasty finish and just kind of pushed the material out of the way.
I don't know the exact type of silicone it is, but one was brown and one was yellow. The yellow one was quite a bit firmer.
It is 1.025 OD x .5 Id x .78 long and I need to bore it to .55 dia.
Any help is greatly appreciated.
10-02-2019, 08:13 PM #2
Freeze and bore, or room temp and grinding pin/die grinder fixtured to tool post. And by freeze, I mean dry ice, not just ~0F.
10-02-2019, 09:07 PM #3
Yup, drop it in liquid nitrogen. Or grind, but before you go jump on the grind wagon, understand it takes a minute to get a system down. A few or several set up pieces.
R
10-02-2019, 09:46 PM #4
A coarse, 40-60 grit, diamond grinding pin works best.
10-09-2019, 08:04 PM #5
10-12-2019, 12:17 AM #6
10-12-2019, 01:59 AM #7
