We have been doing internal subs for years using separate offsets for each position. However, we have some gang loaded parts where using offsets does not make sense. The last time we did this was on a Dynapath so the language was a bit different. Refresh me.
So we need to do mill ops with T1 at G54 X0Y0, then G54 X0Y4, etc. Then run em again with T2. Is this a G52 call?
So maybe...
T1
G54
G52 Y4
G52 Y8
Ops here
M99
Can I do that?
If I am on track here, I should be able to make slight tweaks to each G52 work shift for each tool and position if needed? The goal here is using the same tool path codes for T1 over and over like an internal sub for different offsets, but without the offsets and use work shift.
So maybe...
T1
G54
G52 Y4
G52 Y8
Ops here
M99
Can I do that?
