Rick Finsta
Stainless
- Sep 27, 2017
Alright, I had a job I took on as a subcontractor from my day job while we wait for some machine deliveries. I have a slot about 0.625" long, 0.120" wide, and 0.150" deep (all the way through the stock), so I have it running down about 0.015-0.025" below the part in a clearance slot in the soft jaw) in 1018. All I had to start with were 2-flute TiAlN carbides, 0.0625" tapered to 0.188" shank, 0.250" LOC. Running 8k RPM (everything I've got) I was running a constant engagement path at 8% stepover, 3.8IPM, full depth. It went though four pieces then broke a mill, and then I halved the chipload and the same thing happened. I'm running in an ER25 collet and best I can check (dial indicator) run out looks fine. I was running coolant to flush chips since I don't have air blast.
I've got some 4-flute on the way from Harvey and Niagara at 0.100-0.109" diameter and I don't want to break a bunch of those, too, since I'm basically doing this job for "free" to get some cash flow to the shop and help out a sister company at the same time.
Any starting point on feeds/speeds for this? I'm guessing that this slot was being made using another method by the last subcontractor. Sister company is just in dire straits to meet a deadline while they wait for a shipment from the normal sub.
