Bridgeport EZPathIISD Head stock to Tail stock Alignment
Likes Likes:  0
Results 1 to 3 of 3
    Jul 2015
    North Carolina
    37
    Default Bridgeport EZPathIISD Head stock to Tail stock Alignment
    Hello,
    HELP...
    I have attached a rough sketch detailing my attempts to align the head stock to the tail stock on our BP/Romi 20" x 60" Lathe
    Sketch #3 is a 16" long 1.250 TGP shaft, center drilled on both ends. The shaft was indicated to 0.0005" before centers were drilled.
    Based on this test I thought everything should be good. But this proved different in sketch #1 and #2.
    So I'm chasing my tail....any help would be greatly appreciated.
    Larry
    Sep 2006
    SW Wisconsin
    479
    14
    111
    When I am doing something like this I run the indicator to the headstock end, spin the part and watch the indicator, center the needle in the runout, run it to the tail and spin it and watch to see if the center of needle travel is the same as headstock end. Adjust to center the needle and recheck.
    Ed.
    Jan 2005
    The Netherlands
    5,690
    261
    1425
    Dail test indicator clamped in the chuck measuring inside the taper turning the chuck
    Make sure you have a dail indicater that does not drop measuring upside down
    Some people here say that is possible
    Problem comes when you measure further away Your lathe bed has to be aligned then to get the same measurement
    So first make sure the bedways are aligned (leveled) Then you can be sure the tailstock can be set centered along the whole travel of it
    Peter
