Hello All,
I have a Bridgeport Series 1 3-axis mill that I'm looking to retrofit. I've been looking at the Mach 3 PC based software but that is not set in stone. I know that there are other options that people are utilizing with very good results. My PC is already built and installed in the cabinet, it is a Windows 10 platform, and this particular PC does not have a 25-pin port. I believe I would be utilizing DMM
.75KW NEMA 34 servos and DYN4 Drives. Does anyone have a preference, past experience with a BOB or motion controller or will I need to utilize one of the newer smart BOB's?
Will the BOB or motion controller work with different software packages if I move to something besides Mach 3? I also would like to be able to run my machine lube pump, and mist directly from
the software, it this possible? Please provide you utilized options, would you recommend the components and why?
