howhow
- Jan 15, 2010
- niagara county, new york USA
Hello
I’m a newbie to the forum and to CNC machining
In the process of getting my BP series 2 interact 2 mill up & running
I’m getting conflicting opinions on how the spindle is designed to turn on and speed adjusted - only manually or both manually and with an m03 Snnn code.
The spindle/speed controls operate fine manually
The spindle turns off with a M25
Spindle won’t turn on with m03 or change speed in MDI mode
The Heidehain TNC151b controller indicates it’s sending signal out with the “*” on the monitor
Traced wire from J2 10 on the controller (the spindle on terminal)to cr 15 in panel
Not sure what the next step is?
Should this machine turn on and change speed via the controller?
