I have had a 1981Boss 6 Series II machine since 1985 that is still running with it's original controls and pretty much everything else original. It is rock solid as machines go. I run it daily. Connecting it to a computer, only means someone worked out the 4-wire connection to DB-25 transition so it could be connected to a serial port. I did that to mine many years ago so I could get rid of the teletype, then used various "dumb" terminals to interface with the machine until I got into EZ-CAM programming software. So much easier to create a program and post process it than to type the whole thing into the machine memory. My take on this setup is the owner uses something like EZCAM or BOB-CAD and post processes the machine file to suit the BOSS 6. While this is pretty standard practice with these "non-conversational" machines, it seems very old-timey to some. Most Cad-Cam programs don't necessarily come with the post processing file to do justice to the BOSS 6, but they are available. For the $1500 price, I would jump at the chance myself, especially if it came with the programming computer itself. If the owner is running EZCAM, up to Version 6 or so will run on almost anything - I used a 286 with Windows 3.11 for Workgroups until a few years ago, then went to Windows 98, now running the same program under xp. Doesn't do 3d, but 2-1/2D is fine for me. BTW Spindle taper is NMTB 30 or Erickson QC-30, which is pretty much identical. As far as the stepper motors go, they were so over built, I have never had one fail, and I have had a BOSS5 since 1981. The top rapid travel for the BOSS 6 was 100 IPS, and you could program that as a feed if you dared. The Boss5 was 30 ips top programmable feed, with 50ips rapid, I think. The spindle on the BOSS6 is larger diameter than the BOSS5, but most of the top end is almost identical to a BOSS5. My machine had an air-pressure assisted table elevating screw, which is about the only thing that no longer works.
