I have to cut a coolant groove .375IN. X .187 DEEP 8" deep in the bore of a part, I have a single point high speed tool bit to cut the key with but what is the trick to get the machine to move in a feed mode without the spindle turning????
I tried G98 with a G1 feed command but got no movement.
Is there a canned cycle that works good for keying?
Also, there are 2 grooves 180 apart, is there a code that will rotate and lock the spindle 180 deg. from the first groove? The machine is a 2006 Doosan Puma 400 with Fanuc 21i control. Thanks
