Broaching tool aligment
Likes Likes:  0
Results 1 to 9 of 9
    Jul 2019
    ISRAEL
    10
    Default Broaching tool aligment
    Hi all,
    I have a broaching tool for cutting simple keyways on a mill.
    The tool has a single flat cutting edge. What are the best methods for aligning the flat of the tool with X axis?
    Jun 2019
    Maryland
    141
    23
    You can use spindle orientation M19 to hold ur spindle in line with your X axis. If it were me I would increment your cuts to no more than .0015 to keep from damaging your spindle bearings.
    Jul 2019
    ISRAEL
    10
    Ok that helps. But then i still need to bring the cutting flat side by some angle.
    Im very unexperienced so maybe its something obvious for you. I thought to simply run an indicator somehow over the cutting edge and then adjust the tools orientation by M19.
    I also know that the holder is pulled by the stud but whar locks its rotation with respect to the spindle? Is it a zero backlash match?
    Jan 2012
    Savannah, Georgia, USA
    1,649
    2624
    628
    Careful. M19 is used for toolchange. Alter that clock and changer will crash
    Jan 2012
    1,649
    2624
    628
    I would use a collet and fiddle with it until I got it square with the axis
    Aug 2007
    Northern CA
    988
    26
    64
    Cut the angle you want on a scrap, m19, then move the broaching tool over to the angle you cut, tighten it in the holder. As you make the light cuts suggested earlier move away from the cut then raise up and take another cut untill you get the depth you want.
    Jul 2019
    ISRAEL
    10
    Say i managed to align the tool as i wanted, wont a tool change mess it all up?
    May 2017
    Minnesota
    930
    1103
    573
    Some machines have a spindle orientation option. If it does, M19 P90. should index the tool to the 90° position.
    Aug 2007
    Northern CA
    988
    26
    64
    They go in and out of the tool changer pretty darn close in my experiance.
