Broke my spring loaded tap collet. Any way to fix?
Results 1 to 9 of 9
    Jul 2013
    Indiana
    3,366
    4927
    1720
    Default Broke my spring loaded tap collet. Any way to fix?
    Snapped off this 1/2"-13 tap in the end of this bolt. I got excited and forgot to press in the sleeve on the collet before backing it out. After beating what was left of tap out now I can't get it to move anymore so it won't hang on to the tap. Aside from beating on it with a hammer and screwdriver is there any to fix these things? Thanks
    Brent
    Feb 2007
    Aberdeen, UK
    4,225
    1505
    1855
    Quote Originally Posted by yardbird View Post
    Brent
    Those collets lock by engaging three ball bearings on a very shallow taper. Normally when they seize up or stop gripping the tap it's because the balls have broken.
    It would be possible to replace the balls, but those collets are cheap enough that it's not worth the effort IMO.
  3. Likes yardbird liked this post
    Mar 2015
    Florida
    459
    944
    270
    Absolute fastest way to fix that is...
    Straight Shank ER32 1.0 Floating Tap Tool Holder MariTool
  5. Likes bryan_machine, Dualkit, yardbird liked this post
  6. #4
    May 2019
    1,430
    648
    845
    Quote Originally Posted by Cycle1000 View Post
    Kinda defeats the purpose of a quick change tap collet.
    I tap almost exclusively with this style of quick change rigid holder.
    They make floating holders that take the quick change also, not that that is the solution.
    I'm not quite understanding what the OP is asking
  7. #5
    Jul 2013
    Indiana
    3,366
    4927
    1720
    Quote Originally Posted by Hardplates View Post
    I was finishing up my shift and kinda in a hurry, could'a explained a lot better. The actual collet piece has a spring loaded lip or sleeve on the front of it. When you push down on the lip you are able to slide the tap in and out. When you release it and it returns to outward position the collet then holds onto the tap so it won't come out. Now the thing that get pushed in is stuck in and won't come out so it won't grab onto the tap. I can twist the lip with pliers but I can't get to return to the out position so the tap won't lock in place. Figured before I put it in a vise and start beating on it with a hammer and a screwdriver I'd ask here. I haven't canvassed the whole shop yet but it's the only one I have. These grade bolts are pretty tuff where the business end of the alien wrench goes. I'm lobbying to the powers that be to let me drill oversized holes or to get the threads cut at the mill. Lol...
    Brent
  8. #6
    Virginia
    16,198
    7561
    10805
    Brent
    Wasting time beating on it makes you FEEL better, that's just TWO f**k-ups. Not a lot of use as a BOGO free nor bonus air-miles.
    These goods themselves are no more "unfuckable" than any other hurrieder I go the behinder I be faux pas.
    Go for fast delivery on a decent replacement. Buy two, even. Downtime (avoidance) thing.
    Why did you think "real Machinists" were born with two dicks, like sharks?
    Downtime is f**king expensive is why. Or was it the expense of f**king?
  9. #7
    Feb 2007
    Aberdeen, UK
    4,225
    1505
    1855
    FWIW I avoid using them on the machines as much as possible, they are pretty much relegated to the tapping arm here. I found that there is a measurable difference in tool life between rigid tapping with the quick change collet and a true rigid holder (ER collet etc).
    I don't know if it's because of the poor coaxiality or the loose retention or what, but taps wear out faster and break more frequently in those quick change collets.
  10. Likes yardbird liked this post
  11. #8
    Virginia
    16,198
    7561
    10805
    Quote Originally Posted by gregormarwick View Post
    Don't see them as popular as once was, but the blades in the Ortleib version of Rubberflex get a fair-decent grip on the hard shanks of taps.
    As to "ordinary" general-pupose collets ... on-size / limited-collapse range TG really will beat ER. FWIW - twice the spend on collets - even the half-mm inherently narrower collapse range of TG does that much.
  12. #9
    May 2019
    1,430
    648
    845
    Interesting, I've never noticed a difference, but then again I've never paid much attention to to it either. Now I suppose I will
    I generally only tap mild steel so good taps last a long time. All the SS and more difficult alloys get a single pass threadmill.
