Finegrain
- Sep 6, 2007
- Seattle, Washington
Hi guys,
I am looking at ways to improve thermal comp in my S700X1. I know about the parameters and algorithms in the control, but they are only "mileage-based," ticking the comp up every xxxxxxx meters traveled, essentially. This helps, but doesn't keep things close enough. The rate of thermal comp can be adjusted, but it is still just mileage-based and there are times when the comp is less than or more than needed.
I have a good read on coolant temperature, and have wondered if I could rig something up that would react not to mileage, but to coolant temp, which IME is the strongest indicator of where the machine is going to move.
Note that this is somewhat independent of ambient shop temp -- the machine can be quite warmer than the shop at times.
Thanks, and regards.
Mike
Mike
