Brother MPG by World Encoders....what did the original knobs look like ? (pix) - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,486
    2958
    5836
    Quote Originally Posted by Scottl View Post
    Even something like this wouldn't look bad on that unit. They have other diameters as well.
    http://www.digikey.com/product-searc...2F4&vendor=450
    I dunno man, that one looks too Fadal-ish
  2. #22
    Oct 2006
    Klamath Falls, Oregon
    3,673
    432
    1022
    Quote Originally Posted by Milacron View Post
    You mean 1970s Marantz HiFi?
  3. #23
    Dec 2000
    51,486
    2958
    5836
    Quote Originally Posted by Perry Harrington View Post
    Yeah, that too....Marantz Quadraphonic....LMAO
  4. #24
    Dec 2013
    899
    264
    536
    I found the knobs online by opening up the enclosure and finding the brand and type of switch and doing a search with that info. The knobs are available in a number of styles and colors. They were like fifty cents or a buck a piece.
  5. Likes 2outof3 liked this post
  6. #25
    Dec 2000
    51,486
    2958
    5836
    Quote Originally Posted by BROTHERFRANK View Post
    As it turns out the knobs are a bit unusual in that they use 1/8" D shaped shanks. The vast majority of indicator knobs use 1/4" shanks. I suppose a 1/4 shank one would work if the set screw happened to be in the correct position to seat against the flat of the D shank and still have the arrow or witness mark point at the correct setting.
    (now counting the minutes before Captain Obvious comes on with lightbulb aglow in his head to recommend I make 1/4 to 1/8 bushings....)
  7. #26
    Feb 2005
    Akron, OH
    1,916
    305
    1451
    Lots of 1/8th inch shaft knobs out there.
    http://www.digikey.com/product-detai...737-ND/1201634
    Or if that one's not to your liking there are 191 other options.
  8. #27
    Nov 2013
    Eastern Massachusetts, USA
    5,950
    5433
    5627
    Or buy some of these.
    KR14 TE Connectivity / Alcoswitch | Mouser
  9. Likes Milacron liked this post
  10. #28
    Dec 2000
    51,486
    2958
    5836
    Quote Originally Posted by Comatose View Post
    Yeah you are right... I was mostly going by the Jameco link where there was only one with 1/8" shaft. Digikey has so many my brain freezes up with the selections. To me the ideal would be to go with what was 1/8" in the first place but with the black plastic, pointer tip with yellow tops.
    FWIW, just now ordered 4 of the Jameco yellow top ones for 1/4" shank, and 4 of the Jameco aluminum 1/8" shank ones, so will see which looks and feels the best.
  11. Likes Scottl liked this post
  12. #29
    Nov 2013
    5,950
    5433
    5627
    The secret is to find a similar knob that you like from a major manufacturer and then figure out how to modify the part number to specify say 1/8" shaft instead of 1/4" or yellow cap instead of red. Looking at a few examples from the same manufacturer usually gives clues as to how the part number is structured.
  13. #30
    Dec 2000
    51,486
    2958
    5836
    Below is photo of the end result of my knob search, cleanup and repaint of the MPG pendant body. I used "stainless" color spray paint but it looks like just gray really. I could have found better looking knobs but I just went with the only 1/8" shaft ones that Jameco had and said to hell with it...good enough..
  14. Likes Tonytn36, Edster liked this post
  15. #31
    May 2019
    CANADA
    British Columbia
    Do any of you have any information on the wiring/pinout for connecting the encoder to a Brother machine? I have a machine without the MPG and will need to know which wire/function goes to which pin on the 12pin connector.
