Brother R450 purge/bleed the tool wash?
Results 1 to 13 of 13
    Jun 2012
    Michigan
    5,461
    5121
    3435
    Default Brother R450 purge/bleed the tool wash?
    Is there a way to purge or bleed the return line that goes back into the coolant tank on the tool wash system?
    It's getting pretty loud when we change tools. It's just air,but it's not normal.
    The tool wash container appears to be full when looking at the vertical indicator tube.
    Sep 2014
    2,059
    1605
    1518
    Have you checked your filter?
  3. Likes wheelieking71 liked this post
    Jun 2012
    Michigan
    5,461
    5121
    3435
    Quote Originally Posted by 2outof3 View Post
    The in line filter didn't look bad, we cleaned it.
    Is there a filter inside that tool wash canister also? The one above the filter?
    Sep 2014
    2,059
    1605
    1518
    Quote Originally Posted by Mtndew View Post
    I don't think so, but I would replace the inline filter, use the wash gun to back pressure the wash system to make sure nothing has clogged it up. If you still see an issue time to start working backwards taking the system apart to make sure nothing has made above the filter. Otherwise call a real tech.
  6. Likes Mtndew, wheelieking71 liked this post
  7. #5
    Dec 2007
    Southeastern US
    6,384
    845
    2811
    The tool wash filter is a yarn filter at the bottom left of the machine. You can't really clean them, they are a replacement item. We've had some issues with that system. It is an air-over pressure system. So it fills up the canister with coolant, then pressurizes it with air so you get a high pressure rinse at the spindle. Normally it's a valve misbehaving when you have issues. Either the dump valve, the valve at the side of the spindle or the valve that pressurizes the tank (I think it's the top valve on the valve bank if I remember right). It's really a pretty simple system when you figure it out.
  8. Likes Mtndew, wheelieking71 liked this post
  9. #6
    Jun 2012
    Michigan
    5,461
    5121
    3435
    I have an email into my local tech, but... :crickets:
    Here is a photo of my tool wash, is that vertical tube supposed to be 100% full to the top?
    The hose that goes into the coolant tank spits out air, then a small stream of coolant after every tool change.
    We'll change the yarn filter, but honestly it wasn't bad.
  10. #7
    Sep 2017
    Wisconsin
    1,088
    259
    720
    Ours are all the way up on our M140s.
  11. #8
    Aug 2013
    Chicago, IL
    1,123
    812
    431
    My S700 is NOT all the way up to the top but the air purge is pretty loud and sometimes it will even make a "whistle" of sorts....like blowing across the top of a little brown jug. Fun fact - one job we run has a series of 4 rapid tool changes (i.e. tool change, drill one quick hole, tool change, drill one more quick hole, tool change, etc.) Each time the coolant level in the sight glass drops 1-1.5" or so and does not fill up quick enough so at the last tool change in the sequence the coolant level would fall below the sensor and alarm out...so we added a couple second dwell in-between one or two of the tool changes to give it some time to fill back up it's not the end of the world for us but I know there are people quoting on seconds...
  12. #9
    Dec 2013
    920
    265
    546
    in the expanded tool data screen, you can specify for each tool whether or not you want the tool wash active. If your tool holders are not all Big Plus, maybe you can try turning it off for one non-Dual Contact tool in the program? Another possibilty is the 'yarn' filter is getting full and slowing down the replenishing.
  13. Likes Nerdlinger liked this post
  14. #10
    Jun 2012
    Michigan
    5,461
    5121
    3435
    Quote Originally Posted by BROTHERFRANK View Post
    We're waiting on parts to be sawed, so right now the machine is sitting. I'll definitely change that filter.
    (All of our holders are dual contact)
  15. #11
    Jan 2013
    Gilbert, AZ
    6,778
    8758
    8750
    Both times I heard that whistle in my 650, I changed the yarn fiter and everything went back to normal.
    If you let it go long enough, you will start getting an alarm. I can't remember exactly what the alarm was.
    The whistle snuck up on me real slow, so I didn't really notice it at first.
    But, when it immediately went away after changing that filter? AHA!
    The first time I changed the yarn filter it was so bad I had a hard time getting it out of the darn can!
    I started writing the date on a piece of blue tape on the can after that and changing it every 5 weeks.
    That was a pretty realistic interval.
  16. Likes Nerdlinger, Mtndew liked this post
  17. #12
    Jun 2012
    Michigan
    5,461
    5121
    3435
    Quote Originally Posted by wheelieking71 View Post
    lol damn! Our filter hasn't been nowhere near that bad.
  18. #13
    Jan 2013
    Gilbert, AZ
    6,778
    8758
    8750
    Yea, that was the first time I had the can off. I got that alarm I mentioned, and called Jeff Altimus.
    He said "Check the spindle wash filter. You have only had that thing for a month! You must be running the hell out of it!"
    At the time I was filling a 330gal container with chips (and packing them with a tamper) every day.
    I was averaging 1200lbs of chips per week off the Brother.
  19. Likes Mtndew, 2outof3, mbraddock liked this post
