welderboyjk
Cast Iron
- Nov 22, 2006
- south west michigan
I have an odd question specifically for this machine.
If one wanted to say, do some machining on a pallet then rotate it our to remove a clamp mid program and send it back in, is it possible to do this using only the pallet start button at the load/unload station?
Our local distributor tells us he doesn't think it's possible. It appears that when the pallet switch is set to cycle tables in auto mode we could send the pallet out with an M code but restarting the program from the pallet start button doesn't work. Having to run around to the operators panel and hit cycle start again kind of defeats the purpose.
Is there a work around, an update from Yamazen or is there something we are overlooking?
