Brother Speedio adding a Cycle end Light
Results 1 to 4 of 4
    Jan 2007
    Ohio
    174
    88
    15
    Default Brother Speedio adding a Cycle end Light
    Has anyone successfully added a cycle end light to their Speedio?
    I would be very interested to hear about it.
    Thanks! Joe
    Dec 2013
    765
    239
    452
    Do you want something above your machine like a red yellow green tower light that you can see from multiple directions or is a fairly large red light on the front panel near your keyboard good enough? If you put an M0 before the M30, the red feed hold button will light up. Hit start one time to get it to M30 and ready to run another cycle. If you want a tower light I have gotten 24VDC LED ones from ebay for around 30-35 dollars. There are terminals on the IO board you can use to activate the R-Y-G lights. It's all in the Installation manual. At the back of the manual under Options I believe they show the connector for the tower light or in the External IO section they show the mappable outputs. You can map one to Red, one to Green and one to Yellow. Or you can use a single Red or Green light.
  3. Likes Pete Deal, wheelieking71 liked this post
    Jan 2007
    Ohio
    174
    88
    15
    Thanks a bunch for that info, yes a Tower Light
    is what I am interested in.
    Jul 2015
    Missouri
    83
    100
    36
    Connector from Digikey. Theres a page in the manual for the pin out.
  6. Likes wheelieking71, joesimmers liked this post
