Thread: Brother Speedio Remote MPG
02-24-2021, 08:51 PM #1
FYI, don't drop those, they land wrong and break.
OK. So I dropped the damn thing and it broke the switch that chooses which axis to move. Inside the housing is a nice little circuit board with two rotary switches soldered to it. One switch in good condition. One in two pieces.
Naturally 5 years is too old and the MFG no longer has any parts for those.
Moving on to Yamazen. OUCH! damn those are expensive. So I'm ordering one.
Doesn't mean I'm done trying to repair this one tho.
Does anybody have an old one flying around that has the pitch knob broken and the axis knob functional?
I will make this work again, I just don't know how yet.
02-25-2021, 03:31 AM #2
Any markings on the part? Usually stuff that big is marked with manufacturer and model number. Once you have that, it's probably only a couple bucks a Digikey.
02-25-2021, 06:33 AM #3
Get a 3rd party one and save yourself $1000
Buy Tosoku HC115 MPG Hand Wheels - CNC Specialty Store
02-25-2021, 09:44 AM #4
02-25-2021, 10:23 AM #5
02-25-2021, 10:30 AM #6
02-25-2021, 10:46 AM #7
02-25-2021, 10:51 AM #8
2outof3 liked this post
02-25-2021, 11:04 AM #9
02-25-2021, 11:55 AM #10
Perhaps try gluing it back on? Just be careful to not glue it to the board. My go-to glue for stuff like this is a good epoxy.
After looking at it again the first thing I would try is to find that exact part and if I could get it then see if I could remove the top/black section from the new one and snap it on the section that is soldered on your board. It is an off-the-shelf rotary switch, not a custom-made part specific to your mill.
02-25-2021, 12:13 PM #11
Get everything as clean as you can. Then epoxy the switch case back over the hub?
Otherwise: 12 pin rotary switch - Google Search
If you can figure out the switch manufacturer throw that in the search.
I doubt you will find the actual board. But, I'm sure you can retrofit a new switch there.
EDIT: DS beat me to the glue suggestion! LOL. I agree, a good clear epoxy (not JB-weld).
02-25-2021, 12:16 PM #12
02-25-2021, 12:18 PM #13
wheelieking71 liked this post
02-25-2021, 01:39 PM #14
02-25-2021, 09:42 PM #15
On my old brother I had a. Similar problem. I got new switches from digikey. They’re just pcb mount rotary switches. It takes a little detective work but doable.
02-25-2021, 10:39 PM #16
As in the wash gun has it's own pump? We hooked in a T down at the coolant tank and ran a hose up for a spray nozzle, works like a champ. Maybe $60 total off McMaster, including nice heavy hose, brass fittings, and nozzle.
I love Speedios, but the $920 MPG does seem steep.
TylerD710 liked this post
02-26-2021, 06:28 AM #17
I think I’d have someone print up a rubber bumper protector thingy so it can’t land on the knobs
02-26-2021, 09:15 AM #18
02-26-2021, 09:21 AM #19
02-26-2021, 09:25 AM #20
