Brother TC-R2B
Likes Likes:  0
Results 1 to 3 of 3
Thread: Brother TC-R2B
    May 2019
    Georgia
    Default Brother TC-R2B
    I am working with a Brother TC-R2B and I need to start in a middle of the program (CNC) at the start of a tool.
    Mar 2006
    PHILIPPINES
    2,813
    829
    1203
    Since to didn't ask a question i'm going to assume you want to know how?
    Go to edit, scroll down to the segment you want to start on, go back to run, cycle start.
    Dec 2013
    906
    265
    540
    that's a pallet machine. make sure you set the Pallet Select system to Off. Manually verify that the correct pallet is in the work area, choose the correct program to run. in memory mode cursor down until the arrow is one line below the tool change (M6 or G100) line you want to start at. turn down rapid override, press Cycle start not Pallet start button....
    Yamazen has a Tech Center in Duluth, GA. Give Gene a call at 800-882-8558 ext. 1140 for local Brother support.
