Brother TC-S2C Z axis issues
Likes Likes:  0
Results 1 to 11 of 11
    Feb 2015
    Missouri
    78
    17
    Default Brother TC-S2C Z axis issues
    I was running a small production run this morning. A couple of hours in, the tool dropped lower than it should've and bit into the top of the vise jaw. After clearing the e-stop, the tool was loose from the spindle. I did a tool change and it kicked out that tool as well. I checked the ball bearings in the draw bar and they look fine. I then proceeded to clean all of the 21 tool pockets to make sure it wasn't a debris issue. While going thru tool changes around the magazine, multiple other tools kicked out as well. But not every time. Then when I try to do another tool change, z went up past home and just kept going. I cleared it and finished cleaning. Now tools aren't getting kicked out, but about every 100 tool changes, z goes too high past home. This leads me to think there's a limit switch issue. But I can't find them! Anyone know where they might be on a 2008 Brother TC-S2C? Or what could be causing this issue if it's not the switches?
    Dec 2013
    848
    255
    495
    No limit switches or 'reference' switches. It has absolute encoders. Check to see your Z machine position when you touch the spindle face to 9" of 1-2-3 blocks sitting on the table. Should be 9". Doesn't need to be 9" of blocks, just whatever precision amount you have that the spindle face can reach. Whatever the height is, that is what your Machine Position should be.
    Feb 2015
    Missouri
    78
    17
    I checked the z position accuracy this morning and its dead on. I also ran 100 or so tool changes manually. 1 tool dropped. It looked like it was misaligned in the pocket. Could've been my mistake after cleaning each pocket yesterday. Not sure.
    I then switched to MEM mode and tried to dry run a program with the rapids turned way down. As soon as I hit cycle start, the z axis started to squeal as it ascended. What the hell is going on? I'm totally stumped!
    Dec 2013
    848
    255
    495
    Another item to check is spindle orientation. Also the keys in the tool pockets (ATC grippers) wear and can be replaced. I have seen the spring loaded plungers that hold the tools in the pockets stick (rusted) from poor coolant maintenance in the machine's past. Sounds like you have something going on in the Zaxis. Ball screw? Motor? Amplifier?
    Feb 2015
    Missouri
    78
    17
    Quote Originally Posted by BROTHERFRANK View Post
    Where do I access these things? Are they behind the z-axis way covers?
    Dec 2013
    848
    255
    495
    Motor is at the top, amp in the control cabinet and ball screw behind the covers. PM me and I can get you more info.
    Feb 2015
    Missouri
    78
    17
    PM Sent. Thanks.
    Feb 2015
    Missouri
    78
    17
    Thought it was fixed with cleaning and new grease. Ran for a couple of hours with the occasional squeal when z is above home during tool change. Then a tool wasn't loaded back in the pocket properly and was flung from the magazine as it indexed. And then this:
    Jul 2015
    Missouri
    86
    102
    43
    The video is private but that sounds ominous.. Was hoping you got it sorted.
    Feb 2015
    Missouri
    78
    17
    Quote Originally Posted by TrollTuner View Post
    Video should now be viewable.
  11. #11
    Dec 2019
    Minnesota
    20
    Quote Originally Posted by biglord4ever View Post
    Maybe a broken spring why it isn't pulling tool up
