Jhendrickson
- Aug 7, 2017
Hello everyone. I recently acquired a tc32a and got around to powering it up and have run into a alarm 6321 *position error x* that i cant clear. When I first powered up the machine I had a x over travel - alarm that was relatively easy to correct by moving the ball screw by hand off the - limit switch. Once I moved it off the switch I was able to get it to start homing but hit the e stop in the middle of the homing sequence and how I'm getting a 6321 alarm position error x. In the pos display the machine position is 4.1815 in and the absolute position is 3.1815. I have moved the column all over but these numbers do not seem to change, and the alarm prohibits me from doing the zero return cycle. If anyone has any thoughts on what i might be missing id be happy to try them out. Anything helps at this point.
Jhendrickson
Jhendrickson
