NaRbO
Cast Iron
- Nov 22, 2006
- Windsor ON
Hello everyone,
Our Brother CNC had stopped mid cycle during a tool change. Doesn't seem to be any cause for the stoppage, no power outage or Estop engaged. After running through the recovery procedure the tool arm will not go up. It shifts up a little bit and makes a "clunk" then errors out with a 2055/2046 error. When i try and turn the screw on top of the motor it doesn't want to turn. Seems like something is stopping it from rotating. The arm wasn't quite all the way down when it stopped, the pull stud was in the spindle but just barely. So almost all the way down. I have removed both tool holders as well and moved the X and Z in the negative direction as the book says.
If anyone has any experience with this particular error I would appreciate any help!
Thank you
Thank you
