Busted Talon Grip inserts? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21
    Jun 2015
    392
    80
    96
    correct heat treat ones will fail the same way.
    The way it fails makes me think it doesn't matter what material you're clamping, just how hard. I avoid using them on stainless because I'm probably going to crank it down tighter than with AL.
    Doubling them up per Dan's comment should help. 50% less per talon might fix your problem right there.
  2. #22
    Jun 2006
    Alabama
    1,871
    1083
    734
    I've had it happen, but only on 4340, 17-4, or some other tougher alloy. Never on Alum or mild steel.
  3. #23
    Sep 2017
    Wisconsin
    558
    60
    272
    I have seen it happen when they were tightened too hard. Last time it was 4140 annealed; torqued the raw stock, walked into the office to grab my flash drive, came back out and the stock was sitting on the way cover, the top half of the talon was about ten feet out the door of the machine LOL. Glad it happened before green button time!
    Looked the at wrench and someone had used it and returned it with much higher torque setting. That's on me for not checking but that is a symptom of little to no 5S in the shop; constantly grabbing stuff from one work station for another! It wasn't the first time I came back after a longer cycle, and the wrench had been fiddled with.
  4. #24
    Jul 2010
    eugene,or
    834
    81
    345
    I've never broken a talon grip but then mostly used them on aluminum and plastic and always used multiple pairs per part so ....
    My technique is to "over" tighten them, then back off and tighten them to a reasonable torque. The goal is to dimple the part to provide a grip hold and then reduce the force to not bend the part or over stress the talon grip.
    Like I wrote, most of the time this has been in softer materials but I've done the same on stainless and steel with good results.
    Teryk
    Sent from my XT1710-02 using Tapatalk
