Milling C630 nickel aluminum bronze?
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2016
    79
    61
    Default Milling C630 nickel aluminum bronze?
    Any tips on this stuff?
    It looks pretty close to C955 on paper — so probably quite abrasive, wants really sharp carbide tooling and a pretty healthy cut?
    The part has two tapped holes, one M3 blind and one M4 through; form tap OK or is that asking for trouble?
    Jan 2014
    Temecula, Ca
    3,276
    1396
    4259
    it can be nasty stuff. It likes to close up when you're drilling it. Suggest using back tapered drills. Never tried to form tap it, and I can't see it working. Usually we use H7 taps, as I said, it'll shrink.
    Jan 2007
    Norfolk, UK
    19,855
    15294
    15569
    Evil shite to drill and tap, …...if I could thread mill - I would.
    If you have to tap, use as large a tapping drill as you can possibly get away with.
    Sep 2015
    Ohio
    1,299
    860
    1301
    I have a job I've been doing for years out of this stuff.
    It's abrasive but not too bad. I drill 4 x .098 holes thru the length and use cobalt SML drills.
    Small pecks and good coolant flush because the chips are really small. SFM 70, about .001 per flute. Burrs are really stiff and kind of a bitch, but I use an Exacto knife and tumble them and they seem to be ok.
    The big angle is milled with carbide, no unusual or premature wear.
    The side hole is M5 and tapped with a HSS gun tap thru to the bore. No problems with taps breaking or anything. I tap at 250 rpm. I wouldn't recommend a form tap because this matl likes to make chips. I don't think it would form well at all.
    I used to run these in qtys of 1500, but the product is at the end of its life, so qtys are only 250/yr as spare parts.
