Hello everyone,
I'm a young guy trying to break into machining more and I have finally decided to pursue a Vertical Mill Machining Center. Since I'm new and trying to learn, I'm going for older machines (20+ years) so I don't break the bank. I've been looking at machines with spindles that have <10HP and max RPM 8,000 or less. I realize these specs are at the bottom of the spectrum for machines but I'm starting off with mostly small prototyping. I'm really looking for just a rigid and repeatable machine.
I'm expecting to find a machine like this in the range of $8,000 - $10,000. Am I far off with that assumption?
I've received some advice about going for a HAAS TM1 or Fadal machines in this age range because you can find parts easily for them. I've also been told their control systems are pretty robust. Is this true, are these machines worth it for the price range I'm looking at?
Lastly, does any one have any advice about going after older Milltronics machines? There's a late 90's VM16 I'm looking at with 7HP, 6000 rpm spindle. Has the Centurion 6 control system but I'd like to see if anyone can attest to its dependability this far in its life. Seems to be going for around $7,000, would this machine be worth it at that price? I know the machine was still running when it was decommissioned, it had the same owner for its entire life and he took care of it well from what I hear.
Thanks in advance.
-TK
Thanks in advance.
-TK
