Miserlou57
- Sep 14, 2020
I've searched older posts but it's 2020 and would like a more modern take on this question. I'm looking to get a CNC lathe that fits my needs.
I'm going into business on the side building scale steam and gas engines (I'm otherwise currently employed full time). I've taken a bunch of machining/cnc classes at local community college but don't do it professionally, until now. I'm definitely a beginner at lathe work. I'm looking at doing low quantity production, ranging from 1-off to 50 part runs.
The work itself I think is pretty basic stuff:
Cutting steel shafts ~1" diameter, up to about 10 or 12" in length.
steel pins, i.e. 1144 in varying sizes up to 1" diameter, few inches in length.
Cutting pretty basic radius profiles (i.e. G71) on larger diameter stuff, maybe 6 or 8" diameter, aluminum, cast iron, steel. 11 inch diameter would be a plus but not a hard requirement.
Threading brass & steel custom fittings, but nothing crazy.
No crazy tolerances
The pins/shafts will be seeing press-fits, so a machine that can hold the tolerance necessary for that (.001, tighter?) would be good.
A couple thoughts:
- Pretty sure a tailstock is a hard requirement for the shafts.
- Hand-coding is adequate, but RS232 or equivalent for CAM is a nice plus.
- Not sure tool changer is an absolute necessity. Gang is probably fine, and probably QCTP in a pinch.
- the lathe does NOT need to be a "job shop" workhorse. It will not be cutting 18 hours a day. Maybe a few hours a day, and it may sit unused for days on end.
- I like the Tormach a lot, but I understand it's basically a lot more expensive than a used and far more capable older machine.
- I need something turn-key. I see a lot of people saying "oh you can pick up a 25 year old XYZ cheap and replace the whatever whatever." Sure, if you've been working with that machine for 10 years and know it inside and out. But I don't. I do not have the time or wherewithal to troubleshoot a machine right now.
- I'm not completely sure it makes sense to invest more than 8 or 10k on a machine to begin with, as opposed to outsourcing the parts.
- Since I'm a beginner, it would be nice to have something I can ask others questions about if they crop up.
Basically the options I see are:
Tormach Slant-Pro - seems great, but kinda pricey
Tormach Rapidturn (I have free&unlimited access to a Tormach mill) not sure can handle tolerance
used bigger machines, Hardinge, Bridgeport, Mazak. Good stuff, but not practically familiar with these.
some smaller oddball machines i.e. Microkinetics 1236, Dynamyte 3000 ideal size, but not very familiar.
Familiar with Haas but they seem too big/expensive for my needs.
So, what would you recommend? Would love specific machine models if you know them.
I'm already starting to think I'm asking for the impossible. Sorry for the beginner naivety. Thanks in advance.
No crazy tolerances
A couple thoughts:
