C5 Capto integral shank .5 inch boring bar
Gobo
Titanium
Jun 4, 2013
Oregon, USA
Looking for a C5 Capto with an integral shank .5 inch boring bar. Any 80 degree insert should work. Maybe 1.5 to 2 inch reach. Seems like no one makes such a thing. This is to the sub spindle on a Mori NLX. Limited clearance will not allow me to use a non-integral shank tool.
Smallest Sandvik C5 integral bar I could find showed it had a minimum bore diameter of 20mm. C5-SCLCR-11070-09
Not sure if that helps or not.
Sanvik and ken metal make then down to 3/8 dia cuts I think at .400 with some modifying done to .385 I have a few of the 3/8 and 1/2 ones they use a ccmt 2 series
Circle tool if you want them smaller
MY bad forgot about the "C5 Capto with an integral shank"
could you get one to put a bushing in and run one of the smaller bars
