cuttergrinder
Hot Rolled
- Mar 16, 2007
- Salem,Ohio
This a program I made to test the grooving of a cable drum on a cnc lathe. The one I need to do is much larger but I think I will run this one just to see how it works. Now this is only the finishing pass. I know I will need to rough it out first. These points will be the center of my 1/4" wide radius tool. This will produce an 8" drum With 10" long grooves with a .866 lead. The one I really need to cut is 19 5/8" Dia and 10' long. Do you guys think this will work?
grooving-program — ImgBB
