Calculating coolant concentration when adding coolant
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Aug 2006
    greensboro,northcarolina
    2,145
    108
    400
    Default Calculating coolant concentration when adding coolant
    Is there a handy way to calculate this? Say I have a 100 gallon tank that is 20 gallons low and has a 12% concentration. At what concentration do I mix the 20 gallons I'm adding to get it the 100 gallon tank back to 8%? Or a 30 gallon tank at 6% that is five gallons low, at what concentration should I mix the 5 gallons to get it up to 8% ? Sure would be nice to have a chart, or formula, but there's a lot of variables. We just kind of estimate, but I would like to be more precise. We have 10 different size tanks we are trying to regulate, trying to maintain 8% for all. What method do you use?
    Apr 2006
    Denmark
    407
    767
    74
    An interesting problem in elementary mathematics.
    No doubt somebody will jump in before I manage to pull my thoughts in order at this late hour (2230). Will follow this thread and if no proper answers, I will give it a try.
    Hope you're not running out of coolant in the meantime!
    Regards, fusker
    Sep 2007
    Washington
    4,611
    93
    1132
    Quote Originally Posted by RJT View Post
    If it's too lean, I add 20% mix.
    If it's too strong (usually the case due to evaporation) I add straight water.
    The formula you would use depends on several factors, which makes the formula a bit cumbersome, but OK ...
    Vi = How many gallons the tank currently has
    Vf = How many gallons you want in the tank after adding mix
    Ri = Current concentration
    Rf = Target concentration
    Radd = Ratio of mix to add to the tank
    Vadd = volume of mix to add in gallons
    Vadd = Vf - Vi
    Radd = (Vf*Rf) - (Vi*Ri) / Vadd
    (I think ...)
    Regards
    Mike
    Feb 2005
    8,541
    12062
    9681
    I think the hard part is knowing exactly the volume of MIXED coolant you need to add to get
    the tank full..
    If you want to make it simple.. Its
    The Amount of Concentrate in a FULL TANK
    minus
    The Amount of Concentrate IN the tank
    equals the amount to put in..
    You WANT 100 gallons at 8%, 8 gallons of concentrate in the tank.
    You have 80 gallons at 12%.. 9.6 gallons of concentrate.
    You need to add 20 gallons with NEGATIVE 1.6 gallons of concentrate.
    2nd example.
    30 gallons at 8% is 2.4 gallons of concentrate
    You have 25 gallons at 6%. 1.5 gallons of concentrate.
    You need to add 0.9 gallons of concentrate when you top it up..
    That's a MUDDY mix.
    In the first example, you can't make a concentration that is negative, unless you have
    DARK coolant... Though if DARK coolant touches regular coolant, it turns to pure energy
    and we all die.
    Second Example. .9gallons divided by 5 gallons equals 18% mix.
  5. Likes hobbyman, HuFlungDung, atex57, BSCustoms, NeilJ liked this post
    Oct 2011
    CANADA
    British Columbia
    575
    14
    351
    Quote Originally Posted by Bobw View Post
    and we all die.
    And that is why I never miss a day checking this forum. Thanks I tip my hat.
  7. Likes Bogart999 9, fusker liked this post
  8. #6
    Sep 2005
    Oakland, CA
    2,071
    104
    501
    Adding straight water to correct too high a concentration is asking for coolant problems as it destroys the water/oil emulsion. Better to add a 1 or 2% solution and work that toward your goal than adding just water. If ya RTFM, it usually tells you this. Just sayin.
  9. Likes fusker, Kaszub liked this post
  10. #7
    Feb 2017
    32
    10
    We've been having plenty of trouble with our coolant and pretty sure it is down to us managing concentrations poorly so we've been trying to think of a way to manage this better. I am interested to see how others manage.
    As shown above it's relatively easy calculate how much coolant needs to be added if you know your volumes. Knowing the volume needed to get back to full on different machines is the tricky part in my book.
    What i'm planning on doing is picking an appropriate point on the gauge/tank of each machine and marking this as your refill point.
    Then, using the 5 gallon bucket, figure out how many buckets it takes to get you back to full.
    Now you know the volume you are adding and its the same every time.
    Perform some math wizardry as shown above and print yourself off a pretty chart for each machine with current % and how much coolant to add to the fixed no. of buckets.
    Works in my head anyways but have yet to implement.
  11. #8
    Feb 2009
    Midwestern MN/Wi USA
    1,258
    70
    332
    Dump some water in it and leave few inches for coolant concentration....mixture be damned but the question is as well
  12. #9
    May 2004
    Paradise, Ca
    2,136
    623
    1071
    Quote Originally Posted by Dan from Oakland View Post
    Unless you're running Oemeta Hycut. Straight water is ok with that coolant.
    I find my guys are surprisingly accurate just guessing. One of them will test the additive and oil concentration first thing in the morning, then add whatever mix he thinks he needs after the machines are up and running. We are never more than 1/2% off. Don't over think this.
  13. Likes steve-l liked this post
  14. #10
    Jan 2005
    CANADA
    Saskatchewan
    9,614
    1188
    3296
    the tank full..
    minus
    2nd example.
    That's a MUDDY mix.
    and we all die.
    I hope you're correct, that makes more sense than trying to derive the equation I can never remember
  15. #11
    Oct 2013
    New Jersey
    864
    744
    I think the important question is do you have a refractometer so you can test how the concentration is changing from evaporation and carryout on parts?
  16. Likes TDegenhart liked this post
  17. #12
    Mar 2004
    Waukesha, WI
    7,504
    702
    1817
    I don't put that much worry into it. I check with the refract, and if it's too high, I mix some water with just a splash of coolant, to bring it down. Pour it in, run it and see where it went from there. If you want to run at 8%, don't fret too much if it winds up at 9 or 7. Much more important things to worry about.
  18. Likes fusker liked this post
  19. #13
    Oct 2014
    Ohio
    88
    366
    16
  20. Likes fusker liked this post
  21. #14
    Aug 2006
    2,145
    108
    400
    I agree, knowing how many gallons it will take to fill the tank is an estimate. Some machines get used daily, others may sit for a week idle. Everyone mixing their own will ad more variables, maybe one guy should do it all the time for more consistency, but to really get a handle on it,looks like it should be done daily with each machine. How often do you check / add coolant?
  22. #15
    May 2004
    Paradise, Ca
    2,136
    623
    1071
    We check / add every morning as part of starting up the shop, no exceptions.
  23. #16
    Apr 2006
    Denmark
    407
    767
    74
    Quote Originally Posted by [email protected] View Post
    Quite right. It took me a few hours to construct the equations and nobody would pay me for time and effort. Quite funny, though. I felt quite clever, long as it lasted.
    fusker
  24. Likes DrHook, Mr.Anderson liked this post
  25. #17
    Oct 2014
    Ohio
    88
    366
    16
    TRIM/Master Chemical has an Excel sheet Downloadable Document
  26. #18
    Aug 2006
    2,145
    108
    400
    Mike,
    Using your calculations, what happens when you come up with negative number?
    Vi = How many gallons the tank currently has 85
    Vf = How many gallons you want in the tank after adding mix 100
    Ri = Current concentration 10
    Rf = Target concentration 8
    Vadd = volume of mix to add in gallons 15
    Vadd = Vf - Vi =15
    Radd = (Vf*Rf) - (Vi*Ri) / Vadd Radd = (100 x 8) - (85 x 10) / 15 = -3.33
    Mix at 3.33 % ??
  27. #19
    Nov 2013
    Utah
    2,581
    711
    1377
    You guys need Hobbies, try Curling.
    R
  28. #20
    Jan 2008
    Cary, NC
    105
    39
    19
    Mike,
    The only way to get negative concentration to add is if the amount of coolant in the water is already more than should ever get in the full tank.
    If that happens, it means you added too much coolant at some earlier time. Flush some amount of the mix, recalculate, repeat as necessary until you get a non negative ratio.
