Turbowerks
Cast Iron
- Nov 9, 2018
- Windom
Hi i'm new to this posting stuff but been lurking for a while, but now i need help.
I have a calmotion lan-usb installed on a 4020 with -5 boards in it. problem is i can load the program to the sd card on the lan-usb but it will only transfer about 330 lines and then it just stops. I have tried many different programs, same results. the machine will load by the serial every time no errors. using a ftp file transfer. use a calmotion usb on a mori sl 25 and it has worked flawless. any one else?
