calmotion lan usb fadal problems
Results 1 to 7 of 7
    Nov 2018
    Minnesota
    25
    27
    6
    Default calmotion lan usb fadal problems
    Hi i'm new to this posting stuff but been lurking for a while, but now i need help.
    I have a calmotion lan-usb installed on a 4020 with -5 boards in it. problem is i can load the program to the sd card on the lan-usb but it will only transfer about 330 lines and then it just stops. I have tried many different programs, same results. the machine will load by the serial every time no errors. using a ftp file transfer. use a calmotion usb on a mori sl 25 and it has worked flawless. any one else?
    Jan 2015
    Missouri
    1,003
    210
    609
    Type cd,10 enter
    Type DNCX,(file name)
    Type .nc
    Type +
    That will load the file for drip feeding a large file
    Nov 2018
    Minnesota
    25
    27
    6
    the programs will load just fine into the memory through the serial,so i would think it should load through the lan or usb. the machine memory is empty. 16 mg available
    Jan 2015
    Missouri
    1,003
    210
    609
    Are you wanting it. In the memory for some reason? If so after cd,10 type ta,(file name ).nc+
  5. Likes Turbowerks liked this post
    Jan 2015
    Missouri
    1,003
    210
    609
    Should of been cd,10 enter then ta,(filename).nc+
    Should do it
    I never load to machine memory it just fills it up and slowed it down
  7. Likes Turbowerks liked this post
  8. #6
    Apr 2016
    Arizona
    271
    231
    122
    I had a similar problem and solved it by lowering the baud rate a little. That was with a machine with -2 boards, so YMMV.
  9. Likes Turbowerks liked this post
  10. #7
    Nov 2018
    Minnesota
    25
    27
    6
    Quote Originally Posted by carbonbl View Post
    This worked for me too ! Thanks for the reply changenge from cd,10 to cd,9 workes like a dream. Wonder why Glen Never mentioned this? I would think he would have run into this before. thanks again. Scott
