Ummmh... well, actually? None, really.
You might want to have a few more of your own first.
TWO HP was "over-engineering".
Sure, I have had plenty of thoughts about it. I could go the more technical route and start to disassemble the machine and calculate how much deflection there would be in the spindle shaft with higher loads applied to it. I may also run a battery of tests on the Vari-Speed system for possible instability. If proven unstable, then I could also go direct drive to remove it as a potential problem down the road.
Before making the attempt to reinvent the wheel here, I was just curious to see if anyone has heard of it being done or know of any successes / failures or possible lack of longevity in placing that kind of demand on the hardware.
Are you saying that two HP was already considered to be the upper limit of what the mill could handle? If so, then what would be the limiting factor in only allowing that amount of power in the system?
I don't have the technical manuals on this mill, but it seems that it was built more sturdy than one of those pivoting ram style J-head machines. Being a solid ram, I know that is in my favor.
I don't generally take the mill above 3,000RPM because I find that unless I am running even smaller end mills that could benefit from the increase in RPM, then there is no advantage in taking it higher. I will loose too much torque.
The bearings in the quill / spindle are in good shape and are likely able to withstand several thousand pounds of load before any inclination of a failure can be expected from them. I hear more often that it is over revving the spindle that can cause bearing failure mainly due to the total loss lubrication system that is not able to keep up with the generated heat. Some say this is possible at speeds over 5,000+ RPM and some others claim more like 6,000+ RPM. Nobody had mentioned the possibility of just applying another foot pound or so of torque on system to achieve higher metal removal rates.
The two HP motor that came with my mill is actually rated for up to three HP by a simple increase in frequency and power. But, doing that would limit the duty of the motor to 30min max and also force me to get a device that can adjust output frequency such as a VFD. I would also start to loose the lower end of my operating RPM with that motor operating at a higher frequency. If not, then I could risk overheating the motor by forcing a lot of amps through it at a lower frequency.
My hypothesis is that I may be able to see some benefits from a 3HP motor such as a slightly improved metal removal rate and less of a drop in RPM when under load.
With all of this being said, I only be willing to try this idea out if I felt that there would be no obvious indicators of trouble. The only thing I heard that could be problematic is the Vari-Speed system that came with the mill. I have not had any trouble with mine, but I generally keep it set in one place unless I am doing some drilling or boring or something like that.
