Got a medium short run job for a part with a 7/8 13tooth internal spline. On a similar part, but with a much larger ID, I just ground a top notch threading insert to fit the profile, and clamped it with a standard clamp, just oriented on the face of the toolholder so I could broach it in a C axis lathe.
But on this part, I’m going to use a 1/4” IC T series triangle insert, but the screw for it is very tiny, (M2.2 x 0.45mm). I’m not that familiar tapping that tiny, and I’m also concerned cutting forces may be too much for that screw to handle. I have to make a custom toolholder either way, but I thought about brazing it in. I’m not very experienced in brazing either, from my understanding you want clean, dry, wet able carbide. Because of the PVD coatings on this insert, I’m asking if that can even be brazed in a pocket?
Thanks guys
Thanks guys
