Can a Fadal 4020 be run on Delta 3 phase
Results 1 to 6 of 6
    Dec 2005
    Iowa
    177
    16
    Default Can a Fadal 4020 be run on Delta 3 phase
    I have Delta 3 phase in my shop it's the type with the WILD leg Can a CNC be run on it I understand that you would have to make sure the control part isn't connected to the wild leg Thanks
    Feb 2005
    8,537
    12048
    9674
    There is a transformer in there. You can run it on any damn thing you want... Almost...
    190V to 510V... Its almost like a real CNC machine, but yet, its still a Fadal.
    Dec 2005
    Iowa
    177
    16
    Quote Originally Posted by garychipmaker View Post
    I should have said it is 220 volt delta 3 phase
    Jul 2004
    Wiggins CO. USA
    1,315
    7
    47
    Yup - running 240 Delta 3ph with mine (actual 246-247v and wild leg to ground is 216v)... if I remember right the wild leg is on the center tap of the disconnect box. Dont remember the jumper settings on the transformer though... just followed the labeling and verified with a volt meter - (I think it was at the spindle drive line in maybe?)
    I think I chased wires to make sure that the wild leg didnt end up on the control side. So far in the few machines Ive worked with (Fadal, Okuma, and Mits WireEDM) it seems that center tap is usually where the wild leg ends up. But that may just be coincidence.
    Feb 2008
    Mishawaka, IN
    220
    17
    45
    Even if the machine is tagged 220V it likely has a multitap capability inside. Look at the transformer and the schematic on the inside door. Know that the schematic is for what was originally shipped with the machine and that may be different than what is actually in the machine as these can be replaced.
    Feb 2004
    Napa, CA
    2,587
    43
    682
    Unless something in the machine is running something off of one phase to ground (nominally 110V), it can't tell the difference between the two flavors of 3 phase. Well, other than one will be 220 - 240 and the other 208 for your transformer taps. The "wild leg" only looks wild in reference to ground, referenced to the other legs it looks completely normal. If the machine has 4 wires going to it (L1, L2, L3, and green ground) then you are safe unless it is wired wrong. If it has 5 wires going to it (L1, L2, L3, green ground, and current carrying ground - often white) - then I'd be real careful which leg I hooked to the wild leg.
