Can flood coolant push small tools?
Results 1 to 15 of 15
    Oct 2017
    7
    Default Can flood coolant push small tools?
    So a new guy got hired to our shop recently. He has very little experience doing the kind of work we do, so our foreman's been helping him set up parts and getting him up to speed on the stuff he doesn't know. I check on the new guy from time to time to keep an eye on him, answer questions, etc. Anyway, the other day he was drilling a part with a .086 drill (held in a drill chuck). I noticed he had turned down the coolant pressure and pointed the nozzle away from the drill so the coolant was just pooling on top of the part. He told me the foreman had checked his setup and told him to do that because the coolant would "push" the drill and reduce runout. We both thought this was odd, but the foreman has decades of experience on both of us. So we kinda just shrugged and went about our business that day.
    I'm curious though. Is one of us a moron? We're not talking high-pressure or through-spindle coolant here, just Haas VF2 flood coolant. There were 4 nozzles turned on, so all the pressure was not just concentrated through one or two. I've always had the Haas programmable coolant nozzle pointed at the tip of whatever tool was being used, since, as I understand it, the purpose of coolant is not just to cool the tool but to wash chips out of the way too. Surely a .086 drill is sturdy enough to withstand this kind of pressure. And if runout was that big of a concern, then surely he would have held the drill in a collet instead of a drill chuck anyway.
    Would excessive coolant pressure actually be something to avoid when using a micro tool, say .01 diameter or smaller?
    Sep 2018
    New Hampshire
    14
    Default No Morons
    Quote Originally Posted by KaiserGlider View Post
    i have noticed runout with jobbers but only with smaller drills,( maybe .040?) as well as extra long, like 12-16x diamater. If the foreman said that there is probably a reason.
    I have coworkers who would rather hand tap 40 m2’s/2-56’s and smaller because of “that one job 30 years ago that he scrapped lots $$& of parts due to a junked small tap.
    If the drill is getting enough coolant to stay sharp and clear chips, no harm done.
    Sep 2018
    New Hampshire
    14
    After reading it again about pooling and no direct coolant, sounds like the same coworker I am talking about, (as well as the reason our spot drills and drills have never come out of his machine sharp).
    Feb 2012
    1,600
    979
    1815
    No.
    Force = Pressure x Area
    Force is proportional to the size of the drill. Small drill = small area = small force.
    Long drills might be a different story, but that has nothing to do with the diameter of the drill.
    May 2017
    Minnesota
    1,805
    2369
    1207
    Aircraft length? Maybe, if you're trying to hold tenths on position and not using a spot drill, but then you should be using a stub pilot anyway. Jobber length? Not a chance. HSS or cobalt with a spot, or solid carbide (no spot needed) the coolant force will have zero measurable effect on the position of the hole. More coolant is better to get the chips out.
    Did they indicate the drill in to less than a tenth? If not he's just blowing smoke.
    Jan 2007
    Flushing/Flint, Michigan
    10,430
    603
    8464
    The only thing I can think of is that too much direct coolant flow does not allow the small sized chips to come out of the hole easily, loading the drill.
    In some more rare cases I'd have to disagree that more coolant pushed in up top helps gets the chips out.
    Bob
  7. Likes csteen liked this post
    Jul 2006
    Hillsboro, New Hampshire
    12,948
    2938
    8932
    Quote Originally Posted by Orange Vise View Post
    No.
    Hiya Orange,
    I think there's a little more too it than that. We're dealing with a single supported beam under bending, which has a faster response to changes in the ratio of diameter to length as the diameter gets smaller.
    So for small HSS drills (under .016" or so?) in jobber length I could see some deviation from regular coolant flow pressures. But realistically it's unlikely with drills as large at .040"/1mm unless as suggested it's an aircraft length.
    What can also set up issues is if the drill tip isn't ground correctly, and one flute produces larger chips over the other. Then, the combination of extra surface area for a swinging chip (before separation), the change in CG due to the mass of the chip on one side only, and even chance of a vibration resonance setting up oscillation of the drill - if things work against you, you could have excessive movement of the drill tip, even enough to bang on the side of the work rather than follow the hole if pecking.
    There's a lot of worst-case going on above, but it's non-zero. However, per the OP's description it does seem like it's much ado about nothing. An .086" drill isn't going to notice a ~60psi coolant stream.
  9. #8
    Sep 2008
    2,524
    1872
    1565
    It would take about 5 minutes to check.
    Put an indicator (somebody else's not your own) in a plastic bag, make sure it's sealed, mount the tip of the indicator against the tip of the drill and turn the coolant on. You'll see straight away if there's any deflection.
  10. #9
    Jul 2018
    Massachusetts
    20
    I don't see much issue with coolant effecting drills and my shop runs small stuff routinely. 0-80, 2-56 and 4-40 are normal. The smallest hole are .04 or so and those are fine too (for stub length drills). We may run the pressure below full blast on some machines but not by much.
    I'd say it depends a lot on the job and shop in general. Machining and programming is all about matching the machine, tooling, material type and programming style to get a final product.
    To each his own so let the chips fly !
  11. #10
    Feb 2014
    FL
    4,307
    13554
    5134
    I can run an .017" endmill with 1000psi coolant directly at the tip, and make a hexalobe with +/-.0005" tolerances....
    So I doubt that flood coolant is going to push an .086" drill.
  12. Likes Mike1974 liked this post
  13. #11
    Jan 2014
    Oregon
    765
    192
    562
    It always fascinates me that some people will work their problems small-to-big. I would have a LONG list of things to check (starting with that drill chuck) before I decided the coolant pressure might be causing runout
  14. Likes charlie gary, mhajicek, Chris59 liked this post
  15. #12
    May 2006
    339
    87
    102
    I routinely use a 0,27mm (0.0106") drill with about .250" flute length drilling to 1mm depth in a Swiss mill/turn and I have the oil aimed right at the tool. Lots of oil. It's like several small garden hoses going on it at once. I meet my tight location specs and get hundreds of holes per drill. Hundreds. Of. Holes.
  16. Likes Mike1974 liked this post
  17. #13
    Feb 2020
    Alabama
    366
    151
    104
    Being that you are from California I would bet both of you are morons. But, to answer the question, yes. Coolant can bend a drill, and if using high psi, can break it.
  18. #14
    Feb 2009
    Midwestern MN/Wi USA
    1,413
    74
    406
    No.
    Ha you contradicted yourself with a right answer and ended with a incorrect relation. This is me on a weekend...especially when questioned
  19. #15
    Nov 2014
    Florida
    6,245
    2485
    3096
    Quote Originally Posted by CORONA VIRUS View Post
    Evidence!? We use a .01" @ 50x diameter, drilling from both sides and have the holes lined up well enough to thread .008" wire so I call BS unless you are running a .005" drill ay 5000psi or something.
  20. Likes mhajicek liked this post
