chuck L
- Nov 18, 2007
- Mid Michigan
I have a 2007 - tm-1p without macros enabled and no probe, here is my quest.
I have an assembly made up of 2 parts ( top and bottom if you will ). The two parts have the same G54 X and Y coord values but Z changes ( by the thickness of the respective part).
I am looking for a way to embed something in my G-Code to change the Z value of G54 so I don't have to always
remember to change G54 Z value when running the mating part of different thickness.
I have thought about making one part G54 and the other part G55 (where Z is the only value changed) and maybe I will end up having to do this way if I cannot do it any other way.
Anyone have a way to do this?
