Can I get a Renishaw Wireless Probe for my Centroid Controller?
Results 1 to 11 of 11
    Sep 2012
    Cincinnati
    314
    6
    62
    Default Can I get a Renishaw Wireless Probe for my Centroid Controller?
    I have a Centroid M400 controller with a DP-4 probe. It is a mechanical contact probe with an open-collector output. It died and I can get it repaired, but would really like a wireless probe. Centroid does not offer a wireless probe at this time.
    Does anyone know if Renishaw has a wireless solution that would work for me? I poked around online and did not see what I was looking for and they are closed for the weekend.
    Jul 2008
    Milverton, Ontario, Canada
    739
    233
    332
    I dont see why not. You'll need the adaptation box from renishaw between the wireless reciever and machine interface, but all its doing is opening\closing a contact.
    Sep 2012
    Cincinnati
    314
    6
    62
    Quote Originally Posted by macds View Post
    Any idea what a setup like that costs?
    Feb 2004
    Napa, CA
    2,632
    45
    698
    Look on eBay for the Haas specific Renishaw OMP40 probe and receiver. The Haas ones are dumbed down, basically the receiver takes power and gives you a switch closure on contact. There are a lot of these around, I've bought the whole setup looked like new in the box for $1000 - $1500 a couple of times. The non-Haas receive has some other lines that need to be manipulated, harder to adapt to a control that isn't set up for it.
  5. Likes macds liked this post
    Jul 2008
    739
    233
    332
    Swaft rat is correct.
    I have know idea what sort of i\o the centroid is looking for PRECISELY, but would guess the Haas setup should work.
    As opposed to asking Renishaw, I'd search what other Centroid users have done.
    Jan 2003
    Tel Aviv, Israel
    604
    83
    152
    Quote Originally Posted by swarf_rat View Post
    Haas specific receiver (OMI-2H) is a downgraded OMI-2T. Both receivers can control 2 probes (mostly OMP40-2/OMP60 and OTS). OMI-2T , contrary to OMI-2H, is equipped with LOW BATTERY and ERROR outputs, as well as additional outputs of SKIP. There in no necessity to manipulate them, if you don't need them. Simply leave them as they are.
  8. Likes bryan_machine liked this post
  9. #7
    Sep 2012
    Cincinnati
    314
    6
    62
    Thanks for all the responses.
    Looks like I will be staying with what I got for now. Supposedly Centroid will have a wireless option at some point.
    I am not comfortable with the connectivity of the Renishaw to the Centroid. The Centroid uses an open collector input and the Renishaw output uses a solid state relay. Usually they are not compatible. And the Renishaw needs an output from the PLC to enable it - doable but more involved than what I want to put into it right now. And I would need to convert it from 12VDC to 24VDC.
  10. #8
    Jun 2011
    MEXICO
    36
    Look this option wireless USA made, not to expensive. I will buy one for my Centroid Acorn
    https://drewtronics.org/s5100-wireless
  11. #9
    Jan 2007
    Central FL
    794
    5
    17
    don't hold your breath Tolesh.
  12. #10
    Jul 2008
    739
    233
    332
    Quote Originally Posted by Tolesh View Post
    Im curious Tolesh.
    For the price it might be worth playing with if you have time.
    But for me, I can find renishaw stuff cheap, and know i can get replacement down the road if needed.
  13. #11
    Sep 2012
    Cincinnati
    314
    6
    62
    Update.
    Centroid finally fixed my DP-4 spindle probe this week. Without getting into all the details, very unhappy with the customer service I received from Centroid with the probe. I probably should not be surprised. I do plan on paying them to get my repaired probe back, but haven't been able to get in touch with them over the last 2 days to take my payment info.
    In the meantime, I ordered a full wireless Renishaw system today. I will deal with the necessary inputs, and I believe that I was wrong thinking that the solid state relay will be incompatible with my inputs. After further research, I think it will be fine or I will figure out how to deal with it. I pretty much understand the rest of all the control requirements. I will post a drawing once I get it all running in case anyone else ever wants to do the same conversion.
    I ended up with:
    - OMI-2T optical receiver (2 channel)
    - OMP60 spindle probe
    - OTS AA wireless tool setter
    Thanks for all the feedback!
