Can the "no go" on your thread gage go in just a little?
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Mar 2004
    Waukesha, WI
    7,365
    711
    1824
    Default Can the "no go" on your thread gage go in just a little?
    I've heard many theories on this, and now I've got a situation on my hands that requires me to know the right answer. The thread is an 8-32 class 2 thread. Customer says the threads are "wrong", and the parts are back in my shop. This is in a blind hole. He sent his gage along with the parts, and his gage looks as if it's been through a war zone.
    So, I check it with his gage, and the no go goes all the way into the hole. That I know would be bad. But when I check it with my gage that is less than a year old, my no go will enter about 1 turn, then locks up.
    Is that thread oversize, or is it ok? It's my customers customer, so I don't get to ask the end user anything, and MY customer admittedly knows nothing about threads. It's his job, we just did the machining on it, and he did the grinding of the O.D. I'm just wondering what the correct rule is on a no go thread gage. I've heard many times you are allowed up to 2 turns on the no go, but to me, that doesn't make sense. It's a no go, there for it should not go at all. What's right?
    Aug 2005
    CT
    7,833
    326
    1865
    Would this help: No Go Thread Ring Gages Per ANSI/ASME B1.2-1983
    I hate this freakin new junk here where the link cannot be highlighted!!!
  3. Likes metalmaster10, extropic liked this post
    Apr 2012
    Indiana
    1,708
    1218
    968
    As posted by Seymour, 3 turns unless noted otherwise. I used to make a bunch of parts that only had 5 threads, so we were allowed only 2 turns MAX.
    In your case it sounds like a gage calibration issue.... Someone has a bad gage. That is where I would start.
  5. Likes Dave K, Atomkinder liked this post
  6. #4
    Apr 2012
    Indiana
    1,708
    1218
    968
    I hate this freakin new junk here where the link cannot be highlighted!!![/QUOTE]
    Or the pics can't be scrolled through with the post open, or the posts don't refresh, or the "home" tab logs you out, or the posts show the wrong post time on the home tab....
    Any of those things bug you too? Cause they really suck!
    Sorry Millacron, I'm sure you didn't do the work, but I really think someone dropped the ball.
  7. Likes JohnEvans, ManualEd, TeachMePlease, Bobw liked this post
  8. #5
    Mar 2004
    Waukesha, WI
    7,365
    711
    1824
    Quote Originally Posted by SeymourDumore View Post
    Yes, that did help. I'm looking for answers myself also, and finding that 3 turns is acceptable as a standard. It's not where I would like to run the parts myself, but it appears to be acceptable.
  9. #6
    May 2013
    wi usa
    194
    60
    They can wear and go bad. If his is all beat up and no calibration sticker on it. I would assume his is worn out or damaged. We always used max of 2 and half turns in on no go end, but most of are threading jobs they don't even go a full turn and get tight. Are thread gauges are calibrated once a year and they do wear out.
    We have had it the other way around, where go end was damaged and would not go in. We changed drills and taps chased problem around until we tried a back up no/go gauge and it went in perfect. Looked at bad gauge under magnification and first thread was smashed and rolled over.
  10. Likes dstryr, Matt_Maguire, doug925 liked this post
  11. #7
    Jan 2010
    Gilroy CA
    4,387
    3169
    2450
    2 turns. Drop ship him a gage.
  12. #8
    Mar 2004
    Waukesha, WI
    7,365
    711
    1824
    Quote Originally Posted by dstryr View Post
    Thanks, this seems to be the consensus.
  13. #9
    Jun 2006
    Hawthorne, CA USA
    199
    41
    67
    Default Thread plug gauge
    On internal threads we allow 3 turns of the no-go (Boeing policy per fed std H28)
    Go side must pass with thumb and forefinger.
    If the working gauge rejects the part a master gauge is used for referee.
    In case you did not know working gauges are made near the limits to allow for longer service life. They will also reject good parts near the tolerance limits.
    Master gauges are made on size and should not be used in production due to very limited wear tolerance.
    If you have some thread wires check the customers gauge it might be N.F.G.
  14. Likes DavidScott, doug925, Brian liked this post
  15. #10
    Jan 2010
    Gilroy CA
    4,387
    3169
    2450
    Quote Originally Posted by Dave K View Post
    In the past I'd go back and forth with the customer. Now a days its cheaper (and easier to deal with) to just send them the parts with a brand new calibrated gage.
    I've had customers reject parts by .0001 or .0002. Drop ship them 2 deltronic pins and all of a sudden the parts must have changed overnight because they are no longer rejected.....
    HMMMMM
  16. #11
    Jan 2014
    Temecula, Ca
    2,978
    1316
    3836
    The no go gage may go in up to 3 turns. (that's not my opinion, that's the spec)
    Shops with old wore out thread gages are a dime a dozen. Try checking it with thread wires, take a picture of you measuring their fucked up gage, and sent it back with the parts.
  17. Likes Dave K liked this post
  18. #12
    Jun 2006
    Hawthorne, CA USA
    199
    41
    67
    HMMMMM
    The untrained Q.A. guys I deal with don't understand gauging allowance with Deltronic pins and would
    probably get them stuck in the hole anyway.
  19. Likes Bobw, TeachMePlease liked this post
  20. #13
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,071
    1503
    2480
    Yes.
    1. Drop ship him a gage
    2. Send the parts back
    3. BILL HIM for the parts+ new gage.
  21. #14
    Aug 2002
    West Unity, Ohio
    25,553
    5795
    8174
    Would this help:No Go Thread Ring Gages Per ANSI/ASME B1.2-1983
    Whad'yah mean you can't highlight it?
    Think Snow Eh!
    Ox
  22. #15
    Aug 2005
    CT
    7,833
    326
    1865
    Think Snow Eh!
    Ox
    I mean it was s'posed to look like yours above.
    Red and bold!
    And it ain't got there when I posted the dammned thing.
  23. #16
    Oct 2012
    Menomonee Falls Wi
    424
    8
    51
    Pitch mic the thread gauge and see if it is undersize.
  24. #17
    Mar 2004
    Waukesha, WI
    7,365
    711
    1824
    Quote Originally Posted by rnmmhunter View Post
    Good idea. I did, and theirs is .0015 under mine. How do you actually wear out the no go? It really should rarely be getting screwed into anything, I would think?
  25. #18
    Jul 2007
    UNITED KINGDOM
    4,888
    2636
    2382
    If they're using it on every threaded hole of that size they buy in, it could be a lot of wear. Might be nice to politely ask them what their calibration scheme is for their standards.
  26. #19
    Aug 2005
    CT
    7,833
    326
    1865
    I can see a Go member wearing out due to too much use, but man, you need to make a whol' lotta [email protected] up threads to wear out
    a no-go.
  27. Likes Joe Miranda, doug925 liked this post
  28. #20
    Mar 2004
    Waukesha, WI
    7,365
    711
    1824
    a no-go.
    Exactly! That was my point, this isn't he go, it's the no go. And this thing is worn all the way down the full length of the gage. There are parts here where his no go will bury it'self into the part, and my no go will go in 1-2 turns then lock up.
    Mark-- I have no access to the end user. This is my customers customer.
