I have a relatively new HMC with Fanuc 30iB and linear scales that is experiencing positioning accuracy errors. I am working with the vendor to fix but I wish I had a better fundamental understanding of how things work.
As received accuracy was .0001 to .0009 depending upon which direction position is approached from, i.e. XY, -XY, -X-Y, X-Y.
We removed the backlash compensation in #1851/1852 and the X error is zero but the Y is roughly .0003.
My questions are;
1. Why does backlash compensation affect position with linear scales. Should not the machine go to exactly where I tell it to regardless of any compensations?
2. When I jog with handle and compensation factors in place, reversing direction using a .0001 pulse causes the machine to move .0005 however the Fanuc DRO would show .0001. I do not understand why the Fanuc DRO is not reading directly from the linear scales. After removing the compensation the jog handle is more accurate however not perfect.
3. This jog handle problem is a big deal because I have found when calibrating the probes using P9801K4M180, I get a cal position error of ~.0005. Therefore I have to manually locate the ring gauge and turn off the M180. Since the DRO using the jog handle does not represent reality I have to use MDI to find the ring center which is a PIA. What is everyones experience calibrating probes and letting Renishaw automatically find the center of the ring using M180 vs manually finding the ring?
PS we did verify the machine is reading the linear scales and not rotary by verifying #1815.1 is set to 1. It still appears to me the DRO is seeing the rotary and not linear but the vendor says different.
My questions are;
