Can a Speedio do High Feed Milling with those special cutters. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Apr 2007
    West Virginia
    1,362
    816
    593
    Mhajicek: Are you using with coolant or without? Maybe a stupid question since it's coolant through, maybe could use air through? I'm not setup for either but wondering. These little 3/8" buggers might be worth a try. I don't have air blow on my machine. Been using coolant with steel.
  2. #22
    May 2017
    Minnesota
    1,805
    2373
    1208
    Quote Originally Posted by Pete Deal View Post
    I haven't used them yet, I thought of it too late for the job and finished the job with a bull endmill. Figured I'd get them for next time. I do have 1000PSI TSC, mostly cutting Ti. I do have spindle air blast if I need it for carbon steels.
  3. #23
    May 2019
    1,911
    1056
    1229
    Quote Originally Posted by mhajicek View Post
    I just got some of the Helical 3/8" one piece HFM cutters. Get the whole cutter for the same price others charge for the replaceable tip.
    Helical Tool
    What am I missing cause that says $161 each. I can get Walter and Iscar modular tips for much less than that
  4. #24
    May 2017
    Minnesota
    1,805
    2373
    1208
    Quote Originally Posted by Hardplates View Post
    Interesting, 'cause when I was looking around the tips were well over $100 each. The non-TSC ones are cheaper:
    High Feed End Mills - Steels up to 45 Rc - Variable Pitch - Reduced Neck
    What's a 3/8" modular tip go for?
  5. #25
    May 2019
    1,911
    1056
    1229
    A Walter 3/8" shows $55 each but I'd imagine the price would be better with quantity. It's not through coolant though.
    I missed the TSC part. Have you tried a non through tool but with a holder that directs the TSC at the tool? Or blowing it through a collet or milling chuck collet?
  6. #26
    May 2017
    Minnesota
    1,805
    2373
    1208
    That would probably work well for most cases, I do it a lot with other cutters. The tip price seems to have come down a lot since I last looked into them a number of years ago.
  7. Likes Hardplates liked this post
  8. #27
    Apr 2007
    West Virginia
    1,362
    816
    593
    A Walter 3/8" shows $55 each...
    $55 That's more like it. I did look at the Helical one and the one w/o tsc is closer to $100. Still, $100+ for a 3/8 endmill? They better really last! Maybe I'll look into them. 3/8" would do me pretty well for some of my parts.
