Can you tap too Slow? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21
    Nov 2014
    Florida
    3,939
    1590
    1839
    I don't run the same rpm, but the same feed (15ipm). It's not super fast, but we do form tap all the way to the bottom of the full diameter hole... The biggest thing Ihave noticed is our coolant has a 1-2 second delay before it actually kicks on so I either have to program a dwell, or use a larger (.3) R plane so it's not a big deal to me if I run super fast tapping, plus we don't break taps very damn often so I'm good with what we are doing.
  2. #22
    Feb 2009
    Midwestern MN/Wi USA
    1,349
    74
    370
    I only tap on the weekends and holidays. Very sober at work breaking all those threading tools
  3. #23
    Aug 2010
    Medina OH
    1,953
    175
    896
    I did a bunch of testing on a new Doosan and found that varying tap speeds does greatly effect the hole quality and life of the tap.
    I had to do all this testing because we couldn’t tap much in the Doosan, it kept breaking taps. After almost 18 months of fighting with the MTB, some guys flew over from Korea and found that the machine had issues from the factory that caused the issues.
    So. . . Even if your doing everything right, you can still be doing it wrong!
  4. Likes eaglemike, PegroProX440, Mike1974 liked this post
  5. #24
    Aug 2004
    redding,calif.,USA
    163
    84
    17
    There is no universal speed. To slow is as bad as to fast. Imagine a turning tool trying to cut of the lathe where the stock is barely turning. There needs to be a certain amount of surface speed to allow the material to flow. It's a fair question, this is how we learn.
  6. #25
    Jan 2007
    s w NH
    325
    227
    119
    most of my tapping on a cnc knee mill with free spindle. cnc hand tapped small holes 4-40 & up to 1/2-13 at best guess. often held in Albrecht chuck. never a problem. smaller and larger stuff done with a tap center and the appropriate size tap handle. many jobs just tap drilled and handed off to assistant with drill press and cheap Chinese slip head similar to tapmatic. also never a problem.
  7. #26
    Jan 2014
    Oregon
    280
    50
    139
    Quote Originally Posted by DMF_TomB View Post
    must have been mistaken hand tapping slow for over 4 decades and no problems. got to be cnc people who never do any field machining and manual machining
    Yeah, I've never broken a tap off by hand before.
  8. Likes TeachMePlease liked this post
  9. #27
    Apr 2019
    Arkansas
    862
    276
    324
    Quote Originally Posted by boosted View Post
    Hell I've broken taps without ever getting it into the hole...
    Sent from my Pixel 3 using Tapatalk
  10. Likes PegroProX440, Mtndew liked this post
  11. #28
    Sep 2014
    Georgia
    508
    7
    83
    Default Can you tap too Slow?
    Quote Originally Posted by Fal Grunt View Post
    That’s crazy a friend of mine had a brand new doosan Dnm and it tapped holes terribly. Broke taps all the time and left terrible finishes.
    Pretty much same code and my fadal would tap beautiful holes. I’m pretty sure it was the machine because we tried everything.
  12. #29
    Sep 2017
    Wisconsin
    719
    106
    378
    I had a roll tap application where speeding it up activated the coating and added lubricity, stopping the issues I was having with breaking taps on those parts.
    So the answer is "yes, there are speeds and feeds that are better than others depending on application" LOL.
  13. Likes eaglemike, PegroProX440 liked this post
  14. #30
    Aug 2010
    Medina OH
    1,953
    175
    896
    Quote Originally Posted by Ianagos View Post
    Might wanna have that checked out. . .
  15. #31
    Sep 2014
    Georgia
    508
    7
    83
    Yea I believe Ellison was the seller and they weren’t too fond of doing anything at all. From what I heard terrible customer service.
  16. #32
    Jun 2006
    Thunder Bay Canada
    1,817
    570
    305
    Some time ago I posted a short video of our tech tapping holes in mild steel using an impact wrench. Until I witnessed it I didn't believe it would work. Seems that the vibrations loosened up the chips. He would simply press a nut onto the shank and use a standard impact socket.
  17. Likes KC3KNM liked this post
