Carbide Drilling for EJ Pins
Results 1 to 16 of 16
    Mar 2019
    Michigan
    Default Carbide Drilling for EJ Pins
    Hey,
    I'm on any tips or tricks on carbide drilling. I'm using through coolant. I am trying to use the carbide drill for ejector pins on plastic injection molds. The problem I'm having is the hole is just a little bit too small for my ejector pin. I haven't done much carbide drilling. We have all these carbide drills here. I'm trying to put them to use and save time. Any ideas would be great! Thanks for your time!
    Apr 2006
    Suffolk, England
    881
    94
    238
    Seriously?
    Use a reamer, drilling is a roughing operation and no where near close enough for an ejector pin hole. Many plastics will flash on 0.001" or less and you need it as close as possible.
    Depending on pin length you may want to relieve it as well. In which case, drill, flip over, relieve, and then ream.
  3. Likes DavidScott, toolmaker96, ARB liked this post
    Jul 2012
    Washington
    2,862
    1106
    1148
    What Peter said. I forget the formula but I think you want about 3 diameters reamed then about .005" clearance for the rest of the hole. The tighter clearance helps hold the grease. Also, make sure your reamers are reaming the size of hole you expect, ej holes have pretty tight tolerances.
  5. Likes Peter Neill, ARB liked this post
  6. #4
    Nov 2013
    Utah
    4,566
    1205
    2546
    I'm not a mold guy. But I am a hole making guy. I NEVER use Reamers, I hate Reamers. I drill to size, I can hold .0005" with a Drill. Surface finish isn't as good as a Reamer (theoretically), but Straighness, Roundness and Size are fine. I would recommend a tool, but don't know the material you are working with or the Spindle turning the tool.
    R
  7. Likes lumley32 liked this post
  8. #5
    Mar 2019
    Michigan
    Seriously? Yea, I am serious. I know how to ream and do it the old way, just trying to try new things. See if I can speed up the process. If I can't get it to be consistent and accurate, then I'll go back. You're making it sound bad to try new things. Yeah, I know how to make EJ Pin Holes. litlerob1 Makino 14,000 RPM Spindle I'm cutting P-20 5/32 DIA. and 3/16 DIA.
  9. #6
    Jul 2015
    UNITED KINGDOM
    156
    238
    40
    I used to do a job that couldn't be reamed, we used carbide drills with a DLC, we had to hit 6.35mm -0mm +0.025mm. there were no real tricks to it TBH, drill the hole (in sample material) with an off the shelf drill, measure the hole, get the drills ground the difference, recoat then go to town!
    don't get me wrong if the coating wears then you're out of tolerance, but in some cases, it was worth it!
  10. #7
    Nov 2013
    Utah
    4,566
    1205
    2546
    Quote Originally Posted by novotny731 View Post
    My first call for ANY and ALL drilling operations is Gurhing. Particularly a job that isn't exactly standard. Good knowledgeable customer help.
  11. Likes Dualkit liked this post
  12. #8
    Mar 2006
    PHILIPPINES
    2,456
    547
    783
    I get the part where you want to speed up a process but in your application do you really think that's a good decision? You admittedly are not familiar with carbide drills but since your shop has many of them you want to learn how they work. Great, perhaps play with them on something besides a tool. I'm not sure about the complexities of your tools but typically they are not just a quick job. Some of ours take weeks or months to complete and if I find out somebody has to make a repair because he/she wanted to cut corners it's gonna be a bad day.
  13. Likes Peter Neill, litlerob1, triumph406 liked this post
  14. #9
    Nov 2014
    Florida
    3,733
    1539
    1765
    So drilling ejector holes for the actual mold core/cavity, or the ejector plate itself? In ejector plate, just step up your drill size a thou or so if you want to "one and done" it. If for a cavity, we used to jig grind ours, I think, depending on material being molded. I think glass filled nylon will flash at around .0005" and polypropylene is .001". SO I think it would depend on what you are molding. Hell I wouldn't trust a reamer to hold .0005" for very long so...
  15. #10
    May 2010
    northern Indiana
    145
    15
    Used to do that all the time and then hone or lap the holes to size
  16. #11
    Aug 2006
    Wisconsin
    1,627
    731
    713
    We do it all the time, we use only Mitsubishi drills, they will hold the size, no center drill, straight thru with high pressure coolant. It's actually quite unbelievable that it works, AND you get a much smoother hole compared to reaming.
  17. Likes lumley32 liked this post
  18. #12
    Sep 2008
    1,667
    1099
    972
    If that was the case you wouldn't be asking questions here.
  19. #13
    Feb 2014
    Sunny South West Florida, USA
    2,810
    10573
    3220
    Quote Originally Posted by triumph406 View Post
    To be fair, he said he knows how to make holes, not how to make GOOD holes.
  20. Likes triumph406 liked this post
  21. #14
    Dec 2008
    New York
    10,112
    2627
    Hey,
    length to dia ratio of drill is the most important thing. you can have somebody drill a million shallow holes per days no problems and then drill deep holes and start having massive broken drill problems and high part scrap loss.
    just saying trying to save 10 minutes drilling time and then spending 10 hours dealing with broken drill bits most likely you are creating extra time loss not saving any time by the end of the year.
  22. #15
    Mar 2015
    Michigan
    357
    70
    107
    Quote Originally Posted by 5 axis Fidia guy View Post
    People swear by Guhring, but I'd puts Mits solid carbs right up there with the best of them. The MHS line is specifically designed for drilling ejector pin holes in one shot. They're all double margin whereas I think most "universal" solid carbide drills don't get into double margin until 5 or even 8xD.
  23. #16
    Aug 2013
    Chicago, IL
    846
    597
    319
    Quote Originally Posted by dodgin View Post
    Speaking of double margin, I recently had to cross drill a 1” hole in 3” round annealed 4340. We’re using an Iscar SumoCham insert drill. This time around the drill tips were back ordered so we got an alternative that was in stock...it was the same everything but double margin. The hole was pretty wonky and the surface finish was real bad with big swirls in it. Long story short we got the single margin inserts in and everything was back to being perfect. Any idea why the double-margin was behaving so badly? I always thought double margin just drilled straighter, rounder holes with essentially no trade off.
