Carbide Hob Grinding - Feeds and Speeds Questions
Likes Likes:  0
Results 1 to 10 of 10
    Jun 2021
    Massachusetts
    Default Carbide Hob Grinding - Feeds and Speeds Questions
    The shop I work at recently picked up an Anca FX3 to grind our HSS and carbide hobs. I am new to grinding and looking for information on grinding carbide.
    I have read that carbide hobs are sharpened in one pass at full depth with a slow feed rate. However, this information is out of a shop book that is older than I am and much of the information is outdated.
    I have had semi-good finishes using the same program I use for HSS hobs, but with a diamond wheel. The tolerances for AA ground hobs are tight, so I am seeking any information to improve my process.
    Thanks in advance.
    Sep 2005
    Oakland, CA
    3,007
    581
    958
    Hopefully Carbide Bob will chime in here, but I would call your grinding wheel manufacturer and speak with them. Everything I have read about carbide hob sharpening is that's its better to sharpen more often and remove less material than to wait for the hob to wear excessively and then have to remove a lot of material. Interested in what you find out. Welcome to PM!
    Apr 2018
    8,166
    3992
    Was going to say the biggest biggest MOST IMPORTANT thing when sharpening hobs is to make sure the face of the teeth is exactly radial (unless the hob is marked as having a hook, so always check.) ITW had charts showing what happens to the involute when you get the cutter face off radially, and it ain't pretty. That's even more important than finish or index spacing.
    Jun 2021
    Massachusetts
    The programs used with these hobs has hob shift after every part and sharpened after one full pass across. The wear is minimal for carbide.
    I have been experimenting with the amount of removal, removing less and less. The finish and grind quality is noticeably better with a lower material removal
    Thanks for the advice.
    Jun 2021
    Massachusetts
    Quote Originally Posted by EmanuelGoldstein View Post
    Thanks for the advice. The Anca I use does a pretty good job of probing the flute face. Flute rake is < 5 microns.
    Sep 2005
    Oakland, CA
    3,007
    581
    958
    Just curious- how much are you hob shifting after each part in relation to the circular pitch? Have you seen any difference shifting after, say 10 parts? thanks in advance.
    Apr 2010
    Wisconsin
    6,210
    4261
    3962
    Quote Originally Posted by rhadfield View Post
    I've only minor experience sharpening carbide Hobs, but a bit more sharpening Carbide Shaper Cutters since we started making them ourselves. My experience agrees with this completely. I've found that sharpening more often, and removing surprisingly little translates directly to greatly improved life and quality of cut. We now only take a few tenths off to retain performance. This also has the benefit of preventing some of the more spectacular failures. You might find that your coolant medium will have more impact now that you've gotten to this point. Carbide Bob will have much good information in that area, too. Good luck.
    Apr 2018
    8,166
    3992
    Quote Originally Posted by Zahnrad Kopf View Post
    Coolant ? you're still running coolant ? I thought all you advanced guys had gone to dry cutting now !
    Apr 2010
    Wisconsin
    6,210
    4261
    3962
    LOL. I am referring to the grinding coolant.
    Apr 2018
    8,166
    3992
    Kinda intersting that hob sharpening is generally dry, while shaper sharpening is generally wet. Never wondered about why before ... you gotta answer ?
