Carbide Insert Parts and Usage
Likes Likes:  0
Results 1 to 11 of 11
    Mar 2011
    Geneva Illinois USA
    6,440
    2817
    2524
    Default Carbide Insert Parts and Usage
    I don't do enough with inserts to warrant special attention from a sales person so I will ask the questions here. What are pads and shims and what are they used for?
    Tom
    Jan 2007
    Flushing/Flint, Michigan
    8,789
    470
    7221
    Quote Originally Posted by TDegenhart View Post
    Tom
    Are you referring to the shim seat located below the insert on a standard pin/clamp style holder?
    (kind of an insert below the actual insert)
    Threading or turning or milling cutter?
    Bob
    (PS you will always warrant special attention from the sales people here)
    Mar 2011
    Geneva Illinois USA
    6,440
    2817
    2524
    You have just pointed out what little I know about inserts. The inserts in question are for turning and the holders and inserts are screw secured. But that is not the main question, I know so little that I cannot make an intelligent choice of holders and inserts. Most of what I have done has been strictly by accident. I have hoped to find a publication that covers all these intricacies but I doubt such exists except in company sales literature.
    Compounding the problem is the jobs I do are tough on carbides, slow speed machines, difficult workpiece.
    The specific job I have now is on a 12CK Monarch turning the thread from grade 8 bolts. Slow speed, intermittent cut, hardened thread. I do have flood coolant, This just tears up HSS.
    Tom
    Jul 2006
    Hillsboro, New Hampshire
    9,295
    2200
    6447
    You may want to use a specific cutting oil for threading for this job, not the coolant. Bob knows much better than me, but I'd try a free cutting geometry with the idea that life is not critical, but lowering force and limiting surface "tearing" are helpful.
    Speeding up SFM once you get used to the carbide may help too.
    Jan 2007
    8,789
    470
    7221
    This holder or the SDJC-10-3B you asked me about do not use shims or seats.
    Simple screw downs.
    Laydown threading tools will often have seats on varying angles.
    This so as to rotate the cutting tool for clearance on the front edge when threading.
    As you cut this helix the stock is coming at you down the tools front flank. Hence higher helix, more twist needed using the same insert.
    The thing I see here is basically trying to "Chicago" a bolt meaning leaving the thread but reduce the base behind it.
    What is not working for you? This tool should handle that.
    RPM? Depth per pass?
    Even though supported the L/D here bad. Is a rough off threads on all parts and then a rerun for nice finish out of the question?
    Chips are sliver colored but maybe hard to get to straw or blue on this machine. Yes I have to deal with that also on my SB.
    Bob
    Nov 2007
    Alabama
    1,545
    184
    284
    Most positive rake tooling such as the SDJCR Tool referenced do not utilize sacrificial parts such as seat (pads)
    That I’m aware of.
    Here is a fine alternative BXA size threading tool:
    LAYDOWN THREADING TOOL
    Mar 2011
    Geneva Illinois USA
    6,440
    2817
    2524
    You missed what I said. I cut the threads OFF the bolts.
    Tom
    Jan 2007
    8,789
    470
    7221
    Who missed that? Oh ,,I see.
    A 45 degree lead, (or twist the holder shown) works better when ripping off threads.
    You do not want to be "in sink" or aligned with the old threads.
    The other side or zero lead works but is slower.
    Bob
    Jul 2006
    9,295
    2200
    6447
    Tom
    Yeah, I missed that too. I've used regular LH and RH turning tools to cut off major diameters, just working them in and swapping to get the cut done. Not fast, but it does the job.
    Jan 2007
    8,789
    470
    7221
    It's just weird that you have to do such.
    In the auto world it is banned and you need special sign offs to do such for an assembly but........I think I did this last week on a clamp/fixture.
    Bob
  11. #11
    Nov 2007
    Alabama
    1,545
    184
    284
    This would probably do the job well. It uses 100 degree side of an 80 degree rhombic CCMT 32.51
    SCMCN 10-3B, WWW.LATHEINSERTS.COM
