Cat 30/40 fixture block community design and free cad files - Page 5
Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 168
  1. #81
    Jun 2015
    701
    232
    236
    Quote Originally Posted by ripperj View Post
    Nobody is looking to hurt Franks business.
    He's charging 1 hour's time for it. Can you design and make one in a hour?
    The one I'm working on has dozen of design hours in it, and is made of 20+ parts and will cost 3 hours of time. Even if I gave the blueprints away, it still wouldn't make sense to build your own.
  2. Likes as9100d liked this post
  3. #82
    Apr 2019
    Arkansas
    1,574
    750
    622
    Quote Originally Posted by CosmosK View Post
    Some new guys have more time than money sadly. That's what this post is all about.
    Plus I'm giving some away for free to help one of my employees learn to program.
    Sent from my Pixel 3 using Tapatalk
  4. #83
    Oct 2005
    21,685
    Quote Originally Posted by as9100d View Post
    Don't dig your filthy hooks into me. Go re read my post above and then let's talk about integrity.
    Making a copy for yourself , qty (1) is fine.
    Making CAD & DXf files and freely distributing online is clearly another.
  5. #84
    Apr 2019
    Arkansas
    1,574
    750
    622
    You're an idiot.
    So by your own idiot rules, maritools fixture is a no no because it is a copy of someone else's design from probably 10s of years ago?
    Bet you only take name brand prescriptions for your hemorrhoids also.
  6. #85
    May 2011
    New Jersey
    2,943
    290
    1617
    Come on the this is a good thing let's not bring it down this road.
  7. Likes as9100d liked this post
  8. #86
    Jun 2015
    701
    232
    236
    I don't have any issue with the project. Frank put his design up after the fact in case anyone wanted to just buy one and be done with it. If the purpose is to put on grabcad or whatever and share for free, all good (I still don't think it makes the make vs. buy cutoff). The only ethical problem I can foresee is if it becomes a for-sale product and the seller effectively poaches the design work of 10 people, but I don't think that's where this is going.
  9. #87
    Sep 2017
    Wisconsin
    1,365
    358
    847
    If the gap behind the flange is an issue using dual contact depth with a standard holder, you could always just make a little spacer washer that drops in. Stick some recessed magnets into the main body and then you could store the spacer ring on the opposite side of the holder when it is not being used. Magnets in the spacer would be nice but harder to do with the thickness I would think.
  10. #88
    Jul 2006
    Hillsboro, New Hampshire
    13,045
    2946
    8959
    Digger, you have an interesting viewpoint on this. Wrong, but interesting...
  11. Likes triumph406 liked this post
  12. #89
    guest Guest
    Quote Originally Posted by Rick Finsta View Post
    I don't actually use standard CAT40, DC only.
    A pin in side of the v-groove would be a simple thing and no monkeying around with spacers. Plenty of room to put one on each side so it fits both types.
    Have to look at the holder specs to see how close BT and DC are- they might be close enough to interchange.
  13. #90
    Jul 2006
    13,045
    2946
    8959
    Getting back to the fixture, what would people think of going back to a split clamp for the simple fixture, such that it used the flange OD as the universal clamp point, one tab on the side opposite the clamp (the mounting hole side), and a cam lever rather than a screw to actuate?
    I'm thinking a pivot boss on one side of the split, and a ramp boss on the other, designed for either a pair of flat plates with a couple holes in them to mate with the pivot boss, a rolling bushing (bronze/brass or Delrin/PEEK) and maybe a final metal spacer at the hand end.
    Yes, a little more work, and perhaps only the plate is made as the community part and the actuation lever is thrown together by the "customer". Or heck, it could be for the adjustable screw lock handles of the currently available styles if you wanted to keep it simpler, but I'd like a lever for mine (think bicycle quick release sort of thing).
  14. #91
    Sep 2010
    Oklahoma City, OK
    5,495
    1061
    2397
    Me too, something like a steady rest. A hinge with 2 pivots, and a cam-lock arrangement on the other side.
  15. #92
    guest Guest
    Quote Originally Posted by Cole2534 View Post
    I thought about that too. It seemed a little too complex for the simple version, but it would allow for a good grip on the holder.
  16. #93
    Apr 2019
    Arkansas
    1,574
    750
    622
    I have a solution. I'm currently traveling but once I return back to the shop I'll get it drawn in CAD.
  17. Likes N/A liked this post
  18. #94
    Jan 2009
    Missouri
    138
    241
    37
    Cost [complexity] is obverse of simplicity [or limited capability]. Such a fixture can occupy either end of the spectrum. Be certain, many of the commercial versions weren't by a Toolmaker/ decent Class A; the range of designs suggest desk bound engineers. Long on features, short on longevity, cleaning, issues found in everyday use.
    Can't supply pics don't work there any more, but made people happy. And I'm sure, still in use! Never made a 30, just 40's and 50's.
    Aluminum wouldn't be my choice, due to embedding of chips over time. But use heli-coils for fasteners if you do.
    Horizontal orientation is far more common. Ergonomics is one-half the reason. Other half? Yeah. Many shops have crap benches ill-suited to absorb torque parallel to floor; but laden with enough *hit to counter force in the other plane.
    Seems we usually had heavy tubing of some kind. C1018 be my very last choice being hard to get satisfactory finish.
    1] Prepare OD for a mounting plate [weldment] for secure anchoring.
    2] Depending on your machine resources [workholding] weld plate in place or complete the required taper, extract dimensions from Machinery's Handbook or online. Allow some/ plenty material to gauge line and front face. I like the flange to sit in a loose bore, so body will center in the taper
    3] Establish gauge line and pocket for drive key(s) just like spindle. Unless operator a 7' 300 lbs one key is sufficient, but I'd cut both slots.
    4] Plan the lock of good tensile steel in C washer configuration to slide around holder end. Another heavier type, would swing on a 3/8"or 1/2" stripper bolt. Either way, secure it with two matching fasteners, [not swing bolt]. The variety of cutters makes a quick release unattractive to me, they aren't so flush, compact or long lived.
    5] Mount the key(s), affix to bench.
    It pays to make one, for each pair of same spindles, if they share a bench. If this is a facility doing short run work, make one for each spindle.
    Finally, I'll praise intent of this thread. We don't occupy the same brick and mortar address, so there will be a lot of conversations about how and what if. Personally, the solution process is what will last until I wear it out or desire improvement. If vending is the intent, follow precepts of "Design for Manufacturing".
  19. Likes as9100d liked this post
  20. #95
    May 2004
    669
    222
    120
    As far as the different thicknesses of the holders along the line of a shim how about 3 or 4 set screws from the back side to take up the slack? I have another idea also that uses my swing plate design but rather one on each side that has the 2 different heights. The body would be made in 2 pieces so you can machine out a pocket on each half where the swing plate would be located between the 2 parts. The 2 halves would then be bolted together making machining faster only one part would be machined on 2 sides to countersink 4 bolt holes on the face of the outside part that hold the 2 halves together 2 of those bolts could be used fr the swing pin on the swing plate. The swing plate could be a nice piece that has a finger groove sticking out proud on both sides. If this doesn't make sense I could draw it out tonight.
  21. #96
    Apr 2019
    Arkansas
    1,574
    750
    622
    Quote Originally Posted by gundog View Post
    As far as the different thicknesses of the holders along the line of a shim how about 3 or 4 set screws from the back side to take up the slack? I have another idea also that uses my swing plate design but rather one on each side that has the 2 different heights. The body would be made in 2 pieces so you can machine out a pocket on each half where the swing plate would be located. the 2 halfs would then be bolted together making machining faster only one part would be machined on 2 sides to countersink 4 bolts on the face of the outside part that hold the 2 halves together. If this doesn't make sense I could draw it out tonight.
    I've got the perfect solution for this that doesn't require shims.
  22. #97
    Dec 2015
    Connecticut
    1,387
    32
    468
    Face mounted thumb bolts on a plate??
  23. #98
    Apr 2019
    Arkansas
    1,574
    750
    622
    Think spring loaded plate that pushes up and down the difference between cat 40 and big plus
    Has a tab sticking out to grip with your fingers and on the end has a space for a ball detent to lock in place.
    I've got it all in my head just need to get it in the cad.
  24. #99
    Dec 2015
    Connecticut
    1,387
    32
    468
    Again. What this thread turned into, is not what it started as. The original intent was to build a better widget, designed by members.
    The original intent was not just produce something easily and cheaply available.
  25. #100
    Apr 2019
    Arkansas
    1,574
    750
    622
    Wrong. The thread was created to design a cheap tool fixture for noobs to make without much time so they can use their available hours not unavailable money.
    Making a better tool holder is a side project that will happen because of number 1)
    I'm in a position to make and give away 10 cheap fixtures for free to help my programmer and help folks here that are less well off to buy, don't have the time to make, and/or know someone they can give it to that will appreciate it.
    With such great talk so far I decided to buy a domain and hosting for projects like this to keep track and post all documents for future folks to download and use...for free.
    Why? Because I can and we can.....
  26. Likes jjclear, mountie liked this post
