CAT40 Spindle Rebuild Recommendations Wanted
Results 1 to 14 of 14
    Feb 2013
    Northeast USA
    115
    35
    10
    Default CAT40 Spindle Rebuild Recommendations Wanted
    One of our CAT40 spindles seized up.
    Does that normally get repaired or will we likely need a replacement spindle?
    For repair does anyone have a good recommendation in the Philadelphia/PA/Northeast area?
    Ballpark cost estimate?
    Feb 2015
    Ohio
    330
    89
    96
    What machine? Some are more cost effective to buy an replacement cartridge, others not so much.
    Feb 2013
    Northeast USA
    115
    35
    10
    2001 Hardinge VMC600II. Fanuc motors and control, linear ways, made in taiwan
    Dec 2003
    poulsbo, wa, usa
    391
    23
    158
    I think that was a machine built by First ... if it was? it should be easy to get a new spindle for it or have it rebuilt. as of a couple years ago a new spindle was like $2,200 and stocked in the US ...
    FYI
    First was sold by Sharp for years then they copyed it and make there own and First is being sold under the Acer, webb and a LOT of other names
    Apr 2009
    Ohio
    179
    17
    55
    A replacement spindle for $2200? No way, I'll take half a dozen please.
    I did new bearings and bellville springs in the drawbar, but no taper grinding in a similar TorqCut spindle for just under four grand about 4 years ago. Really happy with these guys service. They are a smaller outfit (I think about 15 to 20 people) than the likes of Setco and offered my small shop quick turnaround when I needed it. I toured their shop and clean room before dropping it off.
    Motor City Machine Tool Repair
    (734) 261-8600
    [email protected]
    Jul 2006
    Hillsboro, New Hampshire
    4,753
    1071
    3270
    Quote Originally Posted by jmullett View Post
    (734) 261-8600
    [email protected]
    Yeah, that's very cheap.
    So why no taper grinding? After reassembly the taper was that good, or did you not want to spend the extra ~$500 for the grind?
    Apr 2009
    Ohio
    179
    17
    55
    They ran it out with an indicator or some kind of measurement device and told me that it wasn't necessary to chrome and grind. They offer the grinding service too so I'm guessing that was their honest evaluation to save on time and cost.
    Jul 2006
    4,753
    1071
    3270
    Huh. Well, that's good, but a little surprising they would of had to chrome it first, if the taper was good enough to use. That implies the that you were right on the edge of getting the tool "sucked in" too far, had that spindle been reground before?
    Apr 2009
    Ohio
    179
    17
    55
    I guess I'm not entirely clear enough on the full process. I thought that chroming was standard part of the regrind process in a spindle taper. In my recollection, it's a bit murky after four years, they put it on some kind of a test stand and measured the runout or profile on the taper or something. Either way I don't recall them saying a taper grind was necessary, or if they did grind it they did not tell me about it. Maybe it was just the chroming that wasn't necessary, but I though they did neither.
    Perhaps the previous owner of the VMC did a grind on it prior to my receiving it.
    Jun 2012
    Michigan
    3,706
    3212
    2142
    I don't know of anyone in the PA area, but Setco does good work. (Michigan)
    High Quality Spindle Manufacturing & Repair - Setco
  11. #11
    Sep 2014
    Georgia
    287
    7
    40
    A fadal spindle isn’t much more. I can easily see how these Asian spindles could be that cheap.
  12. Likes Mstcnc, Bobw liked this post
  13. #12
    May 2002
    South Central PA
    12,712
    1705
    2862
    Try Peiffer - Peiffer Machine Services
  14. Likes Jrill liked this post
  15. #13
    Jan 2014
    Washington
    3,051
    581
    1539
    Not typically. Chroming is needed if the taper is severely damaged or has been reground multiple times or heavily reground. If it needs chroming then the process is to grind, then chrome, then grind again. Adds substantially to the cost of a rebuild.
    Sometimes the bearing seats on a spindle will be scored when a bearing seizes or has spun or fretted. Grind, chrome, grind, can be done to repair that type damage too. Again at a substantial price increase over a "regular" rebuild.
    @OP
    These fellows....
    www.cm-spindle.com
    are the consistently the best I've used. Probably farther away than you want to use, but they've successfully done some for me that other rebuilders effed up.
  16. #14
    Feb 2013
    Northeast USA
    115
    35
    10
    Thanks for the replies and recommendations, really appreciate it.
    I'm not sure how to find someone who would sell a replacement cartridge, but I'd like to know how that compares to the repair cost/lead time. Where would I look to find a new cartridge? Does it have to be the Hardinge part# or are there identical spindles I could get for less that might be stocked in the US?
