gregormarwick
- Feb 7, 2007
- Aberdeen, UK
On our NTX2500.
Must be something I'm doing wrong, but I've had this happen twice now.
Lift a wear offset on a turned diameter, like you do, to creep up on a tight tolerance. I do that, cuts oversize as expected, make the adjustment to wear, I can see the wear update in the tool info window, but it just cuts the same size again. I can continue to drop the wear offset and rerun, but it just keeps cutting the same size over and over.
In both cases I managed to get it take effect eventually by changing something in the tool offset page, like resetting the B axis position or something, but I haven't figured out what exactly fixes it, or have any idea at all what causes it.
Anyone got any thoughts on this?
