claya
Cast Iron
- Aug 6, 2006
- california
We do a fair amount of protos where the stock is larger than the chuck through hole. So have to pre-cut stock to length. And my cutoff saw does not always cut perfectly perpendicular. Are there some old school tricks to centering stock close to minimal runout in the chuck?
I currently set the tool to the stock diameter, and use a square on the opposing/adjacent jaw. Am wondering there is a better way?
If the cutoff saw is not cutting perpendicular in the vertical, does that mean the blade is dull, or the tension or speed is off?
Sent from my SM-G975U using Tapatalk
