Centroid atrump cnc mill conversion to single phase
Results 1 to 12 of 12
    Jun 2017
    Virginia
    Default Centroid atrump cnc mill conversion to single phase
    I have acquired 2 atrump m218 mills with centroid m400 controls and I am looking to see what I can do to run them on single phase power as low cost as possible. They are setup for 220v 3-phase now. Anyone have suggestions? I have read that maybe setup controls on single phase and spindle on rpc but not seen any details about it.
    Mar 2012
    Geilenkirchen, Germany
    2,302
    1390
    1184
    I wouldn't do it. Period! You will not be happy with the results. However, you should consider converting your shop to 3 phase with the use of a single phase to 3 phase inverter.
    Feb 2009
    Wisconsin (from May to November); Florida (from November to May)
    1,612
    46
    406
    Look under Atrump or Centroid videos. There is a training video that shows how to hook up the machine to either single phase or 3 phase power. I have a Atrump B3EC manufactured in 2008 that meets these requirements, and I operate it with 220 volt single phase power.
    Search Centroid Cnc Videos. There is a training video there that is 1 hour and 28 minutes in length, and the wiring for 220 volt 3 phase and 220 volt single phase is covered.
    Jan 2014
    Washington
    4,384
    803
    2362
    Quote Originally Posted by steve-l View Post
    What is the basis of this opinion? Something about a Centroid that does not like single phase?
    I've been running my Mori Seiki on single phase for nearly 4 years now with no problems.
  5. Likes twr, rlockwood liked this post
    Mar 2012
    2,302
    1390
    1184
    This single phase/3 phase issue has been with us for a very long time. All electric motors work by magnetic impulse regardless of their type. The big advantage 3 phase motors have over single phase is a more frequent impulse count per revolution. In other words, they are smoother and smaller for a given power. The dilemma in the US is that 3 phase power only exists in industrial zones and it is very expensive to bring elsewhere. In the past we had pseudo 3 phase generators using single phase input and idler motors as the only affordable solution, but things have changed today. Inverter technology has improved by leaps and bounds. Inverters now can produce very smooth digitally created sinusoidal output both efficiently and inexpensively with very high reliability. We see this most in VFDs, but inverter use has popped up everywhere, including UPS systems. These make a lot of sense, as they can be powered by a multitude of different sources. Where whatever energy source is available, it is converted to DC. This DC can be stored in batteries and/or directly used to produce eclectically quiet, sinusoidal, voltage correct, smooth AC single or 3 phase at any frequency one desires. Most importantly it can done at less cost than either wiring in a 3 phase service or a mechanical pseudo 3 phase system and every day the cost of these inverters drop. I think today, it is the only way to go.
    Jun 2006
    609
    21
    72
    I run one of these every day at my day job. It has pluses and minuses if you need any help with anything quirky about it, maybe I could be helpful to you. We run ours on 3 phase and I don't know anything about wiring for single phase, so I am afraid I can't be helpful there.
    -Greg
    Jun 2006
    Near Seattle
    4,666
    2911
    1232
    At least some atrum's (including mine) have VFD driven A/C spindles - so the question becomes will the VFD be adequate?
  9. #8
    Nov 2007
    marysville ohio
    9,256
    2643
    6110
    My Centroid M400 Bridgeport V2xT is happy to run on a American rotary phase converter. The control runs on 110v anyway. the 3 phase is only for the spindle motor only.
  10. #9
    Jan 2014
    Washington
    4,384
    803
    2362
    No relevance really for users of small CNCs. The OPs mill runs the control on single phase 110 or 220 to start with. The servo drives take the incoming power regardless of single or 3 phase and convert it to DC before output to the motors as DC or digitally created AC and many brands are fine with single phase input. The spindle drive could be inverter driven which in many cases will be happy to run on single phase input too. If the spindle is a mechanical variable speed drive with a 3 phase motor, only then will 3 phase need to be used or an inverter installed to run it.
    Lots of people have thrown away good money adding roto-phase or phase perfect units to run small CNCs that with a bit of thinking, are just fine with single phase power.
    Small machines without hydraulic systems are almost always great candidates for single phase operation.
  11. Likes twr, bryan_machine liked this post
  12. #10
    Nov 2007
    marysville ohio
    9,256
    2643
    6110
    Centroid probably put a VFD in the cabinet so the M400 can control the spindle speed.
  13. #11
    Aug 2014
    Noble, OK
    854
    66
    173
    As Vancbiker said, the controls are run off single phase and the motor is the only 3 phase device. I have a similar setup, although run on 3 phase now, it was connected to single phase previously. I just ran a VFD for the motor and used auxiliary contacts off the motor starters to control forward and reverse. I didn't use the speed control but if your control doesn't specifically have a VFD control, you could swap the speed pot for a different pot and wire straight to the VFD voltage reference input.
    Sent from my HTC One using Tapatalk
  14. #12
    Mar 2018
    UGANDA
    27
    I just bought an Atrump BF6C today. The dealer said I couldnt separate the power and wanted to argue about it so I let it go. He insisted that the entire system required 3 phase and offered to toss in a rotary phase converter to shut me up. I will probably still look into the control box and see what I can do because a 4K spindle is a little bit on the slow side and a motor upgrade or vfd if it’s inverter rated would be ideal. Either that or mount a sub spindle to the side of the head. I imagine the AC servos themselves are 3 phase and not sure other than a phase converter for addressing those so maybe that’s what he meant? The drives are probably 3 phase only. Seems to me I’d have to go to new servos and may as well upgrade entire control at that point. No time at the moment I need a running mill I can depend on.
