plutoniumsalmon
Hot Rolled
- May 27, 2014
- Los Angeles
Hello.
Stupid question. I need to cut 2 parts asap for a client and would really not like to switch chucks. Can I clamp a solid finished bar with cerrated hard jaws and expect an unmarred finish and decent run out if I use cerrated hard jaws in a 3 jaw Chuck for the second op. Most of my work is 3j collet chuck so I never used the 3 jaw that is currently installed on the machine for the 1st op. The part is 6 inches long coming out of pre hardened 4140 I need to od about 2 inches. The part I will be holding is solid with a 32mm diameter.
Thank you.
Thank you.
