Cerrated hard jaws for second op with ph4140?
Likes Likes:  0
Results 1 to 7 of 7
    May 2014
    Los Angeles
    429
    77
    Default Cerrated hard jaws for second op with ph4140?
    Hello.
    Stupid question. I need to cut 2 parts asap for a client and would really not like to switch chucks. Can I clamp a solid finished bar with cerrated hard jaws and expect an unmarred finish and decent run out if I use cerrated hard jaws in a 3 jaw Chuck for the second op. Most of my work is 3j collet chuck so I never used the 3 jaw that is currently installed on the machine for the 1st op. The part is 6 inches long coming out of pre hardened 4140 I need to od about 2 inches. The part I will be holding is solid with a 32mm diameter.
    Thank you.
    Jul 2013
    Indiana
    3,200
    4693
    1619
    I've done it a few times on shit that don't matter, put an indicator on it and see how true it spins. If your serrations are to a bit of a point then yeah you'll leave marks on it. If the serrations are kinda flat should be alright. Don't hog and you should be able to use a little bit of pressure, I've made things under a 100psi many times.
    Brent
    Jul 2013
    Indiana
    3,200
    4693
    1619
    Gripping with all the jaw will be the least amount of flex in the master jaw, flex will make marks. Remember rpm will work against you with low chuck pressure, I'd keep the R's down to a mild roar and not a bazillion mph. Best thing to do grip up on a chunk of 4140PH stock then check the runout. Then see at what chuck pressure you start getting marks that can't be tolerated. Then machine accordingly.
    Brent
    Feb 2008
    MI, USA
    788
    59
    309
    I'm not a CNC lathe guy, just a mill guy.
    But in high school, we had a bunch of Leblond lathes. Ran em a lot. Was told to wrap parts in emery cloth, or with shim stock, if we needed to not have marks in the parts.
    Works okay, it isn't perfect.
    I'd say cut a piece of .010" or .015" shim stock and clamp on that if you can. Should at least reduce what you can see by "smoothing" the teeth bite out a bit.
    Nov 2013
    Utah
    4,482
    1182
    2462
    Just build a precision split ring out of Aluminum. .
    I don't use shim stock, unless I need to. I can't seem to get the part to run true with shims.
    R
    Jan 2019
    SWEDEN
    174
    55
    19
    R
    I second this. Shims are unreliable by nature.
    May 2014
    Los Angeles
    429
    77
    Quote Originally Posted by yardbird View Post
    Brent
    Worked great. Thank you.
