Chatter issues on small OD part
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Feb 2019
    CANADA
    Ontario
    44
    Default Chatter issues on small OD part
    Hey guys, so I'm turning a part which is rather small and the stick out about six inches. I'm wondering what approach you guys would use to make this part? The test piece is 303 stainless and the part itself will be of inconel. I'm not quite sure if there will be a decrease in the chatter when I machine the inconel. Currently, I'm contour roughing the front rad with a vbgt with a .016" rad and leaving .01 in x and .005 on z. Next I'm roughing toward the second rad using a vbgt .0312 rad UM chipbreaker. Leaving .04 in x and .010 in z. The. Starting at the front of the first Rad, blending into it, and finishing at a .040 DOC at 255sfm and .0005 ipr using an vbgt .008. Will post a pic of the part and drawing in a minute once I figure out how to. Any advice will be great. Thanks guys.
    Oct 2014
    Ohio
    182
    711
    40
    Have you considered CNC swiss or other sliding headstock machine?
    What is "rather small"?
    Dec 2015
    Illinois
    385
    124
    215
    Without looking at a picture or print I would suggest trying to cut the part in a single pass.
  4. Likes jmaddock liked this post
    Feb 2019
    CANADA
    Ontario
    44
    Feb 2019
    CANADA
    Ontario
    44
    .160" over 4.2". Needs a 16 finish.
    Nov 2002
    3,242
    1818
    800
    A swiss machine (sliding headstock) or a lathe with twin turrets that allows for "pinch turning" would be my suggestion.
    That probably doesn't help YOU with the part, I know.
    Inco needs to be setup correctly, and machined aggressively.
    A long, thin part, with tight tolerances and fine finishes, is going to be a nightmare!
    Doug.
    Aug 2006
    greensboro,northcarolina
    2,336
    136
    546
    Doug,
    Do you mean twin spindles? Hang on to both ends in chucks or collets and turn between them is what i am thinking.
  9. Likes Fulcircleny liked this post
  10. #8
    Feb 2014
    Sunny South West Florida, USA
    2,667
    10268
    3101
    Quote Originally Posted by RJT View Post
    Doug,
    No he means twin turrets, for pinch turning, so that you're essentially balancing the forces on the OD of the part, making it easier to keep it straight and in tolerance. Like this: YouTube
    But really, this sounds like a Swiss part...
  11. #9
    Nov 2014
    Florida
    3,416
    1473
    1616
    Quote Originally Posted by Tupper87 View Post
    Ok, so I have never cut iconel so I could be FOS with this. Isn't .01" in Z and .04" (doc, so .08" on diameter?) in X a little excessive for finishing? Also, .0005 ipr seems way too low, but again, I've not cut this stuff so maybe that is right?
  12. #10
    Nov 2013
    Utah
    4,360
    1168
    2392
    It is a Swiss part. But you gotta get through it, right? Your feed is way too slow. Do you have a Tailstock? There are ways to set up a sort of make-shift Steady rest. But you need to support it somehow. You could try a Swiss methodology where you Turn segments, then pull the part out as you go.
    R
  13. Likes mhajicek liked this post
  14. #11
    May 2017
    Minnesota
    925
    1087
    567
    Even if you don't pull it out out a bit at a time, turning it a bit at a time may help, especially if the stock is significantly oversize. That way the full stock diameter provides rigidity for the area you're working on at each stage.
  15. Likes Booze Daily liked this post
  16. #12
    May 2005
    CA
    1,124
    8
    284
    A creative follow-rest. Maybe even two of them... one for turning in one direction, and then another tool / follow-rest for finishing up the neck in the other direction.
  17. #13
    Apr 2005
    Beaverdam, Virginia
    7,236
    600
    3391
    How many do you have to make and what time frame? That should dictate course of action. It is an obvious Swiss job. You could also rough them out, send them out to grind diameters and then finish the threads. If you have to make 10 of them and you fight it all week and they still look ugly what have you saved over outsourcing to someone with the right equipment for the job?
  18. #14
    Feb 2019
    CANADA
    Ontario
    44
    Quote Originally Posted by doug925 View Post
    Doug.
    I do have twin turrets. Which I am going to use when the piece comes back from stress relief. The finally OD needs to be .160" so I'll be taking it from .180 down. Hopefully this helps. The only thing I'm unsure of is do I try and pinch turn with an svvbn and finish the entire thing. Or use left and right tools and blend them at the rads. Any thoughts on which would be better? I'm thinking the svvbn would cause more chatter?
  19. #15
    Feb 2019
    CANADA
    Ontario
    44
    Quote Originally Posted by precisionmetal View Post
    I wish I had one BUT I don't think my boss will spring for one atm....
  20. #16
    Feb 2019
    CANADA
    Ontario
    44
    R
    That would be great but the .160 Od cannot have any Mark's as it's considered a weak point. I've tried turning it in segments but it leaves behind indications of where the cutter enters and exits... Unless there is a way to do this without any indications? I'm already a week into this... driving me absolutely nuts.
  21. #17
    Feb 2019
    CANADA
    Ontario
    44
    Quote Originally Posted by mhajicek View Post
    The stock size is .5" which absolutely sucks... The only issue I find with that is it leaves tiny indications of entrance and exit moves.. Unless I'm missing something?
  22. #18
    Nov 2013
    Utah
    4,360
    1168
    2392
    You do it at Transition points, not just in the middle of a controlled feature. But it's not really a method for regular Lathes. So with a great deal of care, you can do it, but it takes time to get it dialed in.
    You need to support the end somehow. BTW you are never going to Pinch a .16" diameter that long. NEVER in a Million years, without support. Right now you need to get it Roughed out to .02" over, so one step at a time. The witness marks don't matter on the rough part. Chatter doesn't matter on the rough part. So just get it to HT for now. After that, support the end one way or another, build a Follow rest that bolts onto your toolholder out of UHMW or something if you want, but you need to support the part. Change your insert to a .001" radius, slow the spindle down to painful, and feed about 10% of the insert radius.
    R
  23. #19
    Feb 2019
    CANADA
    Ontario
    44
    R
    Thank you for the input I was thinking .004 rad in a positive insert I'd need to go to smaller tool holders to get a the rad smaller... I'm still kind of a noob when it comes to these kind of parts so bare with me. You don't think the tailstock alone will be enough support? How would I make a steady rest? I'd need some sort of bearing no? If you wouldn't mind, could you explain how one would eliminate witness marks if I were to machine it in segments?
  24. #20
    Feb 2019
    CANADA
    Ontario
    44
    Thank you everyone for the advice. I really appreciate it!
